Results 1 to 4 of 4
    Jr. Apprentice rwag1945 is a glorious beacon of light
    Sep 2009
    Unhappy 2004 Tahoe Tow Package Wiring
    I have a 2004 Chevy Tahoe, which apparently has a wiring harness problem.
    I have two trailers, both with new wiring harnesses and light assemblies.
    ALL Tahoe lights work fine without a trailer connected.
    Trailers have good grounds.
    The Tahoe plug at the back tests “good” on all connections UNTIL the trailer is plugged in. Then the lights go crazy.
    The Tahoe ground then tests “hot”
    Tahoe lights: none on trailer
    Brakes lights: none on trailer
    Left Directional: good on trailer and Tahoe
    Right Directional: none on trailer; Tahoe works, but both tail lights come on
    Brake & left directional: Trailer has left directional; no brakes; Tahoe ok
    Brake & right directional: Trailer has LEFT directional; no brakes; Tahoe ok
    Lights & left directional: Trailer has left directional; no tail lights; Tahoe ok
    Lights & right directional: Trailer has no lights; Tahoe has tail lights, but right directional stays on and does not blink
    Both trailers have the same performance.
    The Tahoe has a 7 way plug and uses an adapter to go from 7 to 4 for my trailers. The wiring has never been damaged or under water, and has worked fine for five years.
    Can it be the right tail light module on the Tahoe? Wiring harness?
    Sr. Apprentice F E Knucklebuster is a glorious beacon of light
    Jun 2009
    Quote Originally Posted by rwag1945 View Post
    A thought.
    The one thing that they all have in common when plugged in(do not work correctly) but don't share when unplugged(work correctly) is your adapter.
    Have you checked it or swapped it out to test it?
    Sep 2009
    YES, i HAVE TRIED 3 DIFFERENT NEW ADAPTERS. THANKS
    Jun 2009
    I know how aggravating these things can be. I chased a phantom light problem on a Montana that ended up being a poor factory rear light harness.
    Good info here - http://www.rofb.net/faq/faq_trailerwiring.htm
    Since your truck is and has been working fine without the trailer hooked up, I would suspect the trailer(s) - since you said they both have a new harness. Bad ground - nicked wire - mixed wire?
    Any chance you could hook up your trailer to another vehicle? If you have the same result you would know it's the trailers - if it works fine you have isolated it to your truck.
    Good luck - these things are always no fun.
Similar Threads
  1. 99 Yukon & 99 Tahoe police package Same?
    By achipnachair in forum Powertrain
    Last Post: 02-02-2010, 07:16 PM
  2. 2004 Chevy tahoe Wiring Problem
    By rwag1945 in forum Member Introductions
    Last Post: 09-21-2009, 06:32 PM
  3. 2004 Tahoe Trailer Tow Wiring
    By rwag1945 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 09-14-2009, 02:21 PM
  4. 2004 Tahoe wiring problem
    Last Post: 09-06-2009, 09:29 AM
  5. 2004 Chevy Tahoe Wiring Problem
    By rwag1945 in forum General Chevy Tech Q&A
    Last Post: 09-05-2009, 12:29 PM
