Results 1 to 2 of 2
    Jr. Mechanic jbeall is a glorious beacon of light
    Feb 2009
    Default What kind of chassis lubricant do I want?
    Hi All,
    I want to lube the chassis on my 2003 Yukon XL. It's got 57k on it, and I'm the second owner so I have no idea when it was lubed last.
    The manual says I should use "lubricant meeting requirements of NLGl #2, Category LB or GC-LB"
    Does any grease that meets those specs work just fine, or is there anything in particular I should look for?
    Amsoil sells 14oz cartridges of grease for $4.71 (if you're a preferred customer, which I am). Seems affordable enough, and it's synthetic.
    http://www.amsoil.com/storefront/glc.aspx
    Should I go for something else? I could save a few bucks by going with some Coastal grease, but I hardly care about a dollar or two difference--just want whichever grease is going to work best.
    -Josh
    Jr. Mechanic X-Hibition is a glorious beacon of light
    May 2007
    Idaho
    Josh,
    I have Mobil 1 synthetic grease in my grease gun. But then again I also have Mobil 1 in the crankcase, front and rear diffs, and the transfer case.
    Sta-Lube makes a good marine wheel bearing grease that has a higher rating for heat and moisture than their disc brake grease. It's conventional.
    There's two choices for you. I don't know Amsoil.
    1998 K-2500 Suburban
    454 w/ 4L80E
    Suspension Maxx T-Bar Keys Gibson Cat Back K&N Intake
    Mag-Hytec trans pan and diff cover Hypertech Programmer
    MSD 6A, Blaster Coil & Wires Roadmaster Active Suspension
    Hummer H2 wheels w/ BFG All Terrrain T/A KO
Similar Threads
  1. 03 chassis ground location?
    By SoundZman in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-04-2009, 01:08 AM
  2. Replies: 1
    Last Post: 09-23-2009, 02:00 PM
  3. vin location on frame/ chassis
    By clairemont in forum General Chevy Tech Q&A
    Last Post: 12-30-2008, 10:10 PM
  4. Lubricate chassis components ???
    By rwmoorh in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 11-04-2008, 07:30 PM
  5. Unknown Chassis DTC - C3400
    By KeithC in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 06-03-2008, 01:09 AM
