Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jr. Mechanic jbeall is a glorious beacon of light
    Feb 2009
    Default How Much Grease To Pump In When Lubricating Chassis, Until it oozes out?
    Hi All,
    My Hayne's manual says when lubricating the chassis, "Pump the gun until the component is coimpletely lubricated. On balljoints, stop pumping when the rubber seal is firm to the touch. For all other suspension and steering components, continue pumping grease into the fitting until it oozes out of the joint between the two components."
    Seems reasonable to me, but I've had others tell me that you should never pump until it oozes out, you've blown the seal, and that you should *never* pump until it oozes out, just pump until you feel the resistance increase.
    So, who is right here?
    This is on a 2003 Yukon XL.
    -Josh
    Jr. Engineer moosetags is a glorious beacon of light
    Jan 2008
    Santa Rosa Beach, Florida, in the Florida Panhandle, so far out that we are in the Central Time Zone
    All my life I have always pumped the grease until I see it start to appear between the two fittings being lubed. I don't recall ever being told that this is the way to do it. I have just always done it that way. On the other hand, I was never told not to do it that way.
    I'm watching this thread with interest to see the responses on this one.
    Brian McCabe
    '05 Yukon XL 2500 Quadrasteer
    '11 Silverado 3500
    Legend 1st Synthetics is a name known to all
    Feb 2009
    Nationwide
    You should not pump untill it oozes out, this is not good. When doing so you open the seal to contaminants. 2 or 3 pumps on most points should be sufficient, you should notice the seal firm up a little.
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Feb 2009
    Quote Originally Posted by 1st Synthetics View Post
    The Haynes manual seems to imply that the balljoints have seals and the other components do not. I got the quote wrong, here it is with the part I omitted in bold:
    "Pump the gun until the component is completely lubricated. On balljoints, stop pumping when the rubber seal is firm to the touch. Do not pump too much grease into the fitting as it could rupture the seal. For all other suspension and steering components, continue pumping grease into the fitting until it oozes out of the joint between the two components."
    When I read that, I think "balljoints have seals that could be ruptured, and the other suspension and steering components do not have seals that could be ruptured and you should pump grease into until they ooze."
    Is the manual in error, then? All the components that you grease are going to have seals, and thus you should be careful with all of them?
  5. #5
    Feb 2009
    By the way, here's a thread from a Toyota forum where they discuss grease pumping, and the "don't pump until it oozes" thinking is mentioned several times:
    http://www.tundrasolutions.com/forum...ler-shaft-4wd/
  6. #6
    Jr. Engineer Loggerhead Mike is a glorious beacon of light
    Aug 2009
    Franklin, NC
    i pump it about 2/3 full, only because if you fill your whatever boot completely full, how long is it going to take for that old grease to disipate so you can add more? if you fill it around 2/3, every oil change you can add a few more pumps and not bust your boot.
    GM TECH
    05 silverado shortbed
  7. #7
    Feb 2009
    Quote Originally Posted by Loggerhead Mike View Post
    How do you know when it's 2/3 full?
  8. #8
    Legend Mean_Green_95 is a glorious beacon of light
    Apr 2009
    Baton Rouge, Louisiana, United States
    I pump it the grease until it oozes out, unless its a ball joint, or a throwout barring that can be greased. You could definitely rupture the ball joints and if you grease a throwout barring too much, the grease will get on the clutch an then u have not clutch, in a sense.. But you want the grease to be on every square inch of where there is metal on metal contact to insure that they operate smoothly and don't prematurely wear out.
    2000 Sierra ext. cab
    5.3, auto, power everything, Pioneer AVH-2300DVD, Kenwood door speakers, 2-10" MA Audio subs, eBay cai, 1 chamber eBay muffler exiting before tire, 245/75 16 Wrangler Armortracs, 6500k HIDs with relay kit
    1995 Cheyenne C1500 ext. cab(my baby, my first truck)
    5.0, 5 speed, Silverado appearance package, power nothing, bucket seats and console Silverado, painted black interior, eBay halo headlights, eBay chrome tails, eBay cai, dual Flowmaster 40's w/no cats, 15x7 American Racing Hopsters, Walmart fog lights, SS mirrors
  9. #9
    Aug 2009
    Franklin, NC
    Quote Originally Posted by jbeall View Post
    by pushing on the boot. its like a balloon, it should be firm but you should still be able to push it in with your finger
    again this isnt text book only my way of doing it
    GM TECH
  10. #10
    Newbie Chevymomma is a glorious beacon of light
    Sep 2009
    BC, Canada
    So how hard is it to change a boot when it is blown. I did a front break job on my 1993 suburban a few weeks ago and found that the last owner blew out the right side boot. Dad said just keep it greased but I would like to change it. I like to do my own wrenching but everything is over torqued on this truck, it took my husband and one other man to get the lugs off for the break job.
    Chevymomma,
    1993 Suburban K1500
    Formerly owned
    1985 s15 Blazer
    2002 Cavalier
    2000 Venture
Similar Threads
  1. How many Grease Fittings?
    By 178kchevy in forum Lifted & Offroad Suspension
    Last Post: 03-24-2011, 09:03 PM
  2. grease fittings
    By nickgiacalone in forum General Chevy Tech Q&A
    Last Post: 04-16-2009, 12:30 AM
  3. Need grease?
    By 1st Synthetics in forum 1st Synthetics
    Last Post: 03-22-2009, 08:24 PM
  4. Grease Zerks?
    By jbhofc in forum General Chevy Tech Q&A
    Last Post: 01-27-2008, 11:29 PM
  5. Wrong Grease???
    By Mcontrols in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 11-28-2007, 08:20 PM
