Results 1 to 4 of 4
    Sr. Apprentice ferg's04 is a glorious beacon of light
    Aug 2009
    Lincoln, NE
    Default metal cai tube
    So, i have a cheap CAI on my 04 Tahoe and i like the looks and for 150, you can't argue with the results. Problem is that the metal tube gets warm sitting on a radiator hose. is there anything wrong with using insulating wrap and covering the hose or is it designed to dissipate heat? thanks in advance
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    I am guessing your talking header wrap, it would be fine I would think, there some actual wraps that are designed to go around intake tubes too, spectra may have one
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
    Legend ejohnson03 is a glorious beacon of light
    Aug 2009
    Woodhaven, MI
    I wonder if you used the Braided Hose Dressing Cover on the Rad Tube, if it would be cooler?
    I would look a lot nicer.
    Ummm... so your CAI tube runs forward toward the front of the Truck?
    Put a Racing Options CAI on my 94 Silverado and have it pointing over to the Passanger side inner fender. There is an opening there, so it can breathe cooler air.
    Pavement sucks...
    1994 K1500 4x4 Ext. Cab
    PCM chip and Xenon 8000k bulbs
    350cu.in bored over .050"
    balanced Crank, 10:1 compression
    Flat top pistons,cam,ported heads
    Option Racing Cold Air Intake
    Holley Throttle Body Spacer
    Accell Igition, 45kv coil
    FloTech Headers, no CATs, dual exhuast
    Goodyear Silent Armor A/T 305/70-16
    Pioneer SupertunerIII CD USB Bluetooth
    Kicker ZX200.2 ZX Amp
    Kicker Audio COMP 10" Subwoofer
    Aug 2009
    Lincoln, NE
    my intake has a 90 degree bend and the runs to the passenger side as well, it just sits on a hose is all. it came with a piece to hold the hose, so it is expected. i think i will try the dress up kit, i was considering one anyway, thanks
Similar Threads
  1. trimming metal
    By Oklaholdem in forum Lifted & Offroad Suspension
    Last Post: 01-03-2010, 09:08 AM
  2. chipped down to metal
    By kwconch021 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-11-2009, 05:06 PM
  3. Hood inner sheet metal rusting out
    By roycet4 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-19-2009, 07:41 PM
  4. Metal fromt bumper
    By devilsalmostfree in forum Chevy Truck Accessories
    Last Post: 04-20-2009, 12:49 PM
  5. metal bracket under radiator... part name???
    By tedd07 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 01-21-2008, 06:53 PM
