Results 1 to 6 of 6
    Newbie Squidlius is a glorious beacon of light
    Sep 2009
    Question Suspension travel stops
    I picked up a 2003 Silverado 2500 2wd. While replacing my shock I noticed that my front a-arms are sitting on the travel stop rubber blocks. I was thinking, "How is this thing supposed to absorb bumps if it's already sitting on the travel stops?" Is this normal or do I need to raise the front?
    Thanks.
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    How are the springs? It shouldnt be sitting on the bump stops.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
    Sep 2009
    I'm assuming the springs are ok with 100k miles on them. How far off the tire is the lower edge of the front fender supposed to be?
    Quote Originally Posted by vncj96 View Post
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Cool Suspension travel stops
    Does the truck set level from side to side and is the front alot lower than the rear? It sounds like the front springs are worn out. Do you know the history of this truck? Work truck?
  5. #5
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    If it's sitting on the bump stops I wouldnt assume the springs are fine. Depending on how the truck was used previously I wouldnt be surprised if the springs have failed.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
  6. #6
    Sep 2009
    Quote Originally Posted by tbplus10 View Post
    Ok, thanks guys. It was a work truck. I'll check with my dealer.
Similar Threads
  1. starter stops by it self
    By fmcdougle in forum General Chevy Tech Q&A
    Last Post: 09-28-2009, 10:44 AM
  2. Air conditioning sometimes stops.
    By warlockguitar in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-31-2009, 10:06 AM
  3. 99 diesel just stops
    By jknee in forum Diesel & DuraMax
    Last Post: 07-28-2009, 07:55 PM
  4. fob stops working
    By mike41 in forum Chevy Keyless Entry Remotes
    Last Post: 08-24-2008, 07:48 PM
  5. Holiday travel
    By dwill3015 in forum The Coffee Shop
    Last Post: 12-13-2007, 12:36 AM
