    Newbie
    Apr 2014
    Central North Carolina
    Default GMC Transfer Case
    Hi! New to the forum and need information regards 1999 GMC Yukon transfer case. I've had the dealer read the code and they indicated the dash switch was bad. I'm certain that code was set when I pulled the switch assembly and took it to them to see if they could test or had a new one. Neither option could be covered. Bought new switch from Amazon and installed. No change. Ordered new shifter motor. Installed. Installation instructions indicate to install with transfer case in neutral. With old motor removed, you can shift the case to the various modes you want. After installation of new motor and vehicle on stands, started engine with AT in PARK. All OK. Shifted AT to neutral and pressed 4 LO switch. Shifted to 4 LO with no problem. Pressed 4HI; shifted, no problem. Pressed 2WH, shifted to two wheel. Tested wheels after each shift; proper wheels and drive shafts rotated when they were supposed to. Needed to
    clear the garage and go to bed. Next day fired it up, pressed 4HI, nothing happened. It will not shift again. My question is - has any one gone through the various shift points using a wrench? How many detent positions are there? How much torque do you think it should take to shift between the various positions. I expected 4 detent positions being 2WH, 4HI, 4L, N. I only found 3. Hope someone has been there, done that. Thanks in advance!
    Quote Originally Posted by Diesel6_2 View Post
    I cant be leave no one has gotten back to you on this. I really cant help much, just wondering why you installed it in neutral then when you started it put it into park. Can you hear the motor turning when in neutral engine off, and you hit the button?
    Newbie
    Apr 2014
    [QUOTE=Chesters;616064 Can you hear the motor turning when in neutral engine off, and you hit the button?[/QUOTE]
    No, it does not turn. I think the shift mechanism in the transfer case is binding and stalling the motor; thus my question of 'how many detent positions should I feel when shifting it with wrench, and how much force should it take to shift between the detent positions'.
    I also can not help you on this one. But, maybe @RayVoy or @Jcat can. They seem pretty knowledgeable in this area.
