Results 1 to 10 of 14
    Sep 2006
    High Deserts of SoCal
    Default Automatic Transmission exploded views
    I'd like this to be a series of exploded views of automatic transmissions. Please submit any pics/diagrams you have of GM automatic trans. (May create a manual trans version if there is enough interest)
    1st up submitted by Jimmiee the 4L60E
    High Desert SoCal
    02 Honda Civic LX
    Default Nice
    Hey thats my tranny! am going to be putting one in my truck here shortlyit blew up
    Here's a picture of the Quick Disconnect Cooler Line. It's the same at the radiator as it is on the transmission. Also the top line on the radiator is the return back to the transmission on most trucks.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    OBD I is all GM up to 1995. To retrieve codes on OBD I vehicles simply jump the terminals A & B with a paper clip or cotter pin. The Check Engine Light will blink out your codes. OBD I codes are 2 digit codes. The light will blink "12" which is a 1 blink followed by 2 blinks before and after the codes are flashed out. If there are no codes you will just get the "12" which means no codes present.
    Sep 2006
    Quote Originally Posted by Jimmiee View Post
    I had to replace my hoses and instead of buying the factory lines from the dealer I bought some high quality hose and a nipple style connector/adapter that NAPA sells. My application was for a heater hose, but I'm sure they sell them for cooler lines.
    Sep 2006
    Default TH400 Exploded view #1
    Here is a view of the TH400
    Sep 2006
    Default TH350 Exploded View #1
    Here is a diagram of the TH350
    http://transmissionrepairboston.com/...r42_design.jpg
    Oct 2010
    Schertz, Tx
    4l80e
    07 Silverado Z71, 6.0L, Turbonetics T-76 @ 10 psi, 75-shot, Comp 212/216 .560, 4L80, Yank 3000, meth injection, Magnaflow dumped, e-cutout, Nelson tuned
    Best time: 12.99@112
    check out helpwrench.com
  1. Automatic Transmission Issue?
    By chevytruckman in forum GM Powertrain Tech
    Last Post: 11-15-2009, 04:45 PM
  2. Automatic Transmission Identification
    By unplugged in forum GM Powertrain Tech
    Last Post: 10-09-2009, 10:55 AM
    Last Post: 06-08-2007, 11:53 AM
  4. Replies: 0
    Last Post: 06-08-2007, 09:20 AM
