I've checked and replaced the bulb, its good. checked the wiring and cleaned it, its good. checked fuses they're all good. front blinker works and blinks fast meaning one of the lites is out but i cant figure out what it is can some one help
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
yes i checked the sockets, switched out bulbs played with the wiring. i dont know what else to check
Well, i know im new here, but ill give it a shot. I had the same issue with my Sunfire. First off, pull the connectors off. Take your test light and see if you even have power coming back there from the signals. If you do, then just the socket is bad. Its hard to tell sometimes bc they will go bad and you wont even know it and think its the bulb. Also, if i remember right, i had a 99 Tahoe and it started doing that. I replaced the plastic bulb connectors (im not sure of the exact name) that hold all 3 bulbs (Stop Tail B/U bulbs) and everything was fine after that. Apparently those years were prone to having those things go bad. Hope this helps!! Good luck, and keep us posted as to what u may find!
2002 Cadillac Escalade AWD
Sittin pretty on 22"!
I had that problem in my Cheyenne 1500 come and go and it was a pain to track down but turned out to be a bad connection in a plug and not the socket
Jim
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1970 Camaro
2007 FJ Cruiser
Bookmarks
