I'm trying to change my pads and rotors on my truck. And there are 2 torx head bolts that hold the caliper in the caliper bracket. I need to get at least one of them out in order to swing the caliper out and get the old brake pads out. And i can't get the stupid things to budge! I've soaked them in pb blaster and even taken an impact gun to them and all i'm doing is breaking the teeth off my torx bit. Any suggestions other than drilling them out? Or if anybody has any creative ways to get the old pads out and the new pads in without having to remove them bolts i'm all ears!
Brian
2004 Chevy Silverado Z71
5.3L V8
61k'ish miles
Red Extended Cab
The workhorse
1999 Mercury Cougar
2.5L V6
60k'ish miles
Pearl white with black racing stripes
The bitchy younger step-brother
Nevermind! I figured out a way. I'm taking pics and when i'm finished i might try to write up a how-to for future use.
Brian
5.3L V8
61k'ish miles
Red Extended Cab
The workhorse
1999 Mercury Cougar
2.5L V6
60k'ish miles
They could be reverse threaded.
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
No, they're not. I tried going both ways with the impact gun. A few times the bolt would move a little bit both ways but then completely locked up all together. It doesn't matter now, anyways. I figured out a way to get past removing those pins. It's a bit of a pain in the ass but it's doable. I'm finally finished with the front drivers side corner. I just finished removing the old rotor on the other side and just taking a quick break to get something to drink and rest my knees. They don't like the hard floors...even with kneepads...
My mother always told me when i was young that whenever i get frustrated about something to stop and calm down. Then look at it calmly and think about it. I should learn to head my mothers words more often...
Brian
5.3L V8
61k'ish miles
Red Extended Cab
The workhorse
1999 Mercury Cougar
2.5L V6
60k'ish miles
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
Yep breaker bar is the way to go!
I was using a breaker bar...or something similar at least. The biggest problem was keeping the torx bit in the bolt head. The depth of the torx head is so shallow that when you try to put pressure on the breaker bar it just wants to pop out. That's how i chipped the torx bit the first time. I'm not sure what brand my bits are. I think they are a step above harbor frieght but not by much. Snap On tools are good, but massively expensive...i should know, i have several sets of allen sockets and extensions. At the moment i can't afford good tools like that so i'm stuck with the cheapys for a while.
Brian
5.3L V8
61k'ish miles
Red Extended Cab
The workhorse
1999 Mercury Cougar
2.5L V6
60k'ish miles
I know you already got them broke loose, so I won't waste my time on that part. But I just finished a brake job on my Silverado (05'), and instead of putting the old crappy torx but bolts back in I went to Auto Zone and found these. They are a hex head caliper bolt, this is what the replacement bolts are no matter where you go. Even the Chevy dealer uses these, because I checked with them before I bought them. They were $7.00 for a set of 2, I replaced all of mine for a better piece of mind. Hope this helps!
A shot of anti-sieze on the bolts goes a long way towards making the next brake job a much easier chore.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Bookmarks
