I have had several folks try to help, but the problem still exists on my Tahoe. I found a melted/missing prong on my connector, which I have replaced. Also the 7-4 adapter, 4 wire pigtail and trailer harness are all new. All circuits test properly at the connector...until the trailer is plugged in and then everything goes haywire. The trailer has a good ground, and I have pulled all of the grounds in the rear of the Chavy wiring harness and cleaned them. The Tahoe lights work fine and there are no fuse problems. The only item I cannot test is a small box located near the Tahoe right tail light. When it is unplugged, there are about 15-20 prongs, all clean and in good shape. Is this some sort of solid state module that could have been damaged when the connector prong melted?
Anyone who can solve this gets a BIG kudo!
Thanks,
Ron
Do you have the same problem with other trailers or just this one?
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
I was going to say the same thing try another trailer
2009 chevy 1500 z71 4x4<br>
2.5 ccm level,2.5 inch rear blocks 305/60/18 coopers stt,Debadge,Black Bowties,Black out interior trim that wasnt already black,Dynatech headers,10 series muffler dual side in front of right rear, com,Edge, KN CAI, Black out exterior completely
Yes..I have a boat trailer that does the exact same thing. They have worked fine since 2004, now both have problems. I'm sure it's not the trailers. Thanks.
Bookmarks
