Results 1 to 3 of 3
    Newbie jkapernicus is a glorious beacon of light
    Sep 2009
    Default Drive side spkr won't work 07 Silverado
    The driver side speaker in my 2007 Silverado goes in and out (usually out). Seems like a loose wire but I have no knowledge of how to work with car radios. What should I do?
    Jr. Mechanic Oscarvan is a glorious beacon of light
    Aug 2009
    Bethlehem, PA
    If it was mine I would remove the door panel and check to see that the wires are properly connected to the speaker. Then I would try to replicate the problem by moving the wires around. If that doesn't work you can try swapping the speaker with the right one, and see if the problem moves to the other side, then you know it's the speaker.
    Is yours a classic or a "new" 2007? I don't know about the classic, but if it's a new you will find a plug connecting the door harness to the truck, located on the left end of the dash. You have to open the driver door to see it. (The lid) Check to see that the plug is properly seated.
    If none of the above works you will have to dig deeper.
    2008 Suburban 1500 LT with all the goodies.
    2009 2500 Crew Cab DMax LT Stock under the hood.....Nerf bars, cap and liner, de-badged, Husky Liners, CB, JVC woofer, bull bar. Roof lights
    Sep 2009
    thanks. I'm pretty sure its a classic. I'll try the fix and let you know if I figure it out.
Similar Threads
  1. 97 Tahoe - driver's side blinker and brake light doesn't work
    By BlackHawk99 in forum Audio / Video Electrical
    Last Post: 11-02-2009, 09:03 AM
  2. Drive doesnt work but '1', '2' and '3' do
    By kiknit in forum Powertrain
    Last Post: 08-24-2009, 09:45 AM
  3. Replies: 0
    Last Post: 07-20-2009, 12:20 PM
  4. Saturn Offers Aura Side-By-Side-By-Side Test Drive
    By Steve in forum Automotive News
    Last Post: 06-12-2007, 08:00 PM
  5. You drive on the WRONG side of the road
    By Steve in forum The Coffee Shop
    Last Post: 03-04-2007, 12:34 AM
