Results 1 to 3 of 3
    Jr. Apprentice Pedro is a glorious beacon of light
    Sep 2009
    Lloydminster, AB, Canada
    Default Idle Trouble
    I recently rebuilt a 350 engine that I stroked because I had a 400 crank available, but that's besides the point. The motor's got about 1000 miles on it since the rebuild and it ran strong with no problems, but now when it's running at idle, after about 10 seconds the engine starts to die and I have to pump the gas to keep it going. My fan belt squeaks like crazy when I rev it up to keep it going, and my voltage meter drops from about 15 to below13, which is when the engine usually quits. Could this be an electrical problem that's killing my power that's killing my spark? Is it a carb problem? The engine doesn't cough or backfire as it dies, it just slowly misses until it dies. Any thoughts? All help is greatly appreciated, thanks.
    Jr. Mechanic okysmokey911 is a glorious beacon of light
    May 2009
    Well I was going to try to help you haha but you said that your engine has a carburetor. If it was a TBI then I would advise unplugging the ecu for about 5- 10 minutes, but seeing that it is not I am not sure. Check the connection to your alternator and make sure your alternator is good.
    Sr. Mechanic Z-71 is a glorious beacon of light
    Nov 2008
    Michigan
    So this just started happening?What do you run for a carb?How does the truck start cold and how about hot?Any smoke out of the exhaust?
    03 Chevy Silverado 1500 ext cab Z-71
    79 AMC Spirit GT
    77 Olds cutlass supreme
Similar Threads
  1. 2004 gmc 4.3 v6 idle trouble
    By tad32287 in forum Chevy S10 Forum (GMC Sonoma)
    Last Post: 08-23-2010, 01:07 PM
  2. RIM - Trouble!!!!! PLEASE HELP
    By CanadianFrybag in forum Chevy Truck Accessories
    Last Post: 07-11-2010, 11:44 AM
  3. Trouble with Idle on 94 silverado 5.7 350
    By Colton5292 in forum Powertrain
    Last Post: 02-07-2010, 10:12 PM
  4. Trouble with a CAI
    By jjjg_02 in forum General Chevy Tech Q&A
    Last Post: 01-07-2010, 08:13 PM
  5. 99 Sub Trouble NEED HELP!!!
    By ljjcsautomotive in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-18-2007, 09:20 PM
