I'm looking for info on changing the fluid in the electronic transfer case for an 01 Silverado
Do you have the traditional part time system (2H, 4H, 4L) or the Autotrak (2H, 4Auto, 4H, 4L)? I'm not sure, but I believe the traditional set up simply uses DEXIII ATF. The Autotrak requires the special (and to my knowledge dealer only) blue AT2 fluid.
When changing the fluid, be sure to remove the fill plug first before draining (just in case the fill plug is seized). You want to know you'll be able to fill it before it's drained.
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
In that case, the only additional thing I will add is that the fill plug on my autotrak t-case (NV246) takes a 5/16" square fitting. I couldn't find one off the shelf, so I bought a cheap 3/8"-1/4" adapter and ground the 3/8" square end down to 5/16". If you find yourself in the same situation, you might consider the same approach.
Bookmarks
