Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jr. Mechanic Oscarvan is a glorious beacon of light
    Aug 2009
    Bethlehem, PA
    Default LT tires on Suburban.....
    OK, I couldn't stand it anymore, and went and got 265's for the 245's on my new 2500HD. Now, the Suburban also has 16" wheels, and could use some tires..... How would an LT tire do on the Suburban? On the 2500 they were blown up to 60F80B.....that's waay too much for the Suburban. How much lower can I run them at without screwing up the wear pattern?
    2008 Suburban 1500 LT with all the goodies.
    2009 2500 Crew Cab DMax LT Stock under the hood.....Nerf bars, cap and liner, de-badged, Husky Liners, CB, JVC woofer, bull bar. Roof lights
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    I've got LT265/75/16 on my K1500 running at 35 psi (as the door sticker says), and they do just fine.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
    Jr. Engineer moosetags is a glorious beacon of light
    Jan 2008
    Santa Rosa Beach, Florida, in the Florida Panhandle, so far out that we are in the Central Time Zone
    Default Greetings from the Florida Panhandle
    I have 2500 Suburbans now and formerly had an '01 2500 Suburban. All of these came with LT 245R75 16 tires. Ireplaced them all with 265R75 16's. All of these were load range E's. I have always run 80 psi rear and 70 psi front. I regularly pull a 7400# Airsrteam travel trailer. These pressures have always worked well for me.
    Brian McCabe
    '05 Yukon XL 2500 Quadrasteer
    '11 Silverado 3500
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    Nothing wrong with upgrading to LTs. Do some searching on tire pressure. I've written a couple lengthy posts on how to set it properly.
    BTW, the pressures you are running on your 2500HD are way too high. Unless you are running over GVWR.
  5. #5
    Master Mechanic KidHauler is a name known to all
    Jan 2009
    MI
    I run LT265's on mine. 50psi any given day; 60/80 when towing.
    They ride fine, and they're pretty quite, for a big 'ol truck.
    1999 Chevy K2500 Suburban 350
    K&N, reworked cai, Thrush cat-backs
    Vinyl, cranks, floor shift, and rear air!
  6. #6
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    tire manufacturer settings, no reason to go past that, you do and something happens now the insurance company has a leg to stand on.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  7. #7
    Aug 2009
    Bethlehem, PA
    Thanks all, you've answered my question.
    That's what's on the door...... 60 front 80 rear, BUT I will only run that when towing the 8000 pound camper. Right now they're at 52 front 68 rear. (Any less and the TPMS will have a fit)
  8. #8
    Sr. Apprentice jtwh20 is a glorious beacon of light
    Dec 2008
    Cary, NC
    Quote Originally Posted by KidHauler View Post
    same here - the rears can go up to 80 if I'm towing...but that is rare
    burbn' in NC
  9. #9
    Sr. Apprentice raueda1 is a glorious beacon of light
    Dec 2008
    NY
    Quote Originally Posted by MrShorty View Post
    Does the door sticker specify LT's? My dear departed 1996 K1500 did specify LT's and 45F50R if I remember right. I think they dropped LT's on the 1500's a couple years later and dropped the recommended pressure along with them. My buddy had a '99 and also ran 35. He was stunned that I was running 50 psi.
  10. #10
    Legend Eddie Z71 is a splendid one to behold
    Mar 2009
    Colorado Springs, CO
    Hi, I am running the same 60/80 when towing like KidHauler. It works great.Then back to 50 psi.
Similar Threads
  1. 1999 Suburban Wheels/Tires
    By 99Burbn in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-25-2010, 12:36 AM
  2. 1988 suburban tires?
    By urbansuburban in forum Wheels & Tires
    Last Post: 02-17-2008, 05:21 PM
  3. 99 Suburban tires
    By cdmax in forum Wheels & Tires
    Last Post: 10-30-2007, 09:40 PM
  4. Can stock 89 2500 suburban use 255/85 R16 tires?
    By Big6ft6 in forum Wheels & Tires
    Last Post: 08-24-2007, 05:16 PM
  5. Suburban-Sized run-flat tires??? [Expired Topic]
    By Steve in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-26-2006, 10:04 AM
