Results 1 to 3 of 3
    Newbie Chevymomma is a glorious beacon of light
    Sep 2009
    BC, Canada
    Default High oil pressure
    Hello,
    I searched the forums but didn't find a answer to my question so I thought I would post this, it maybe answered somewhere that I didn't look so be kind as I am new.
    My truck is a 1993 K1500 4x4 Suburban with a fuel injected 350. When I bought it 2 months ago the oil gauge read a steady 200 except on a cold start where it ran for a few minutes at about 300. Now I am blowing oil out around the rocker covers, and the pressure is always between 300 and 400 cold or warm even when the oil is low. I am not even sure where to start on this, I have never had this problem on a truck. The oil filter is not ballooned, yet. Any ideas as to where I should start?
    Chevymomma,
    1993 Suburban K1500
    Formerly owned
    1985 s15 Blazer
    2002 Cavalier
    2000 Venture
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    300 kPa is 43 PSI. That is just right. The oil coming out around the valve covers means you just have bad gaskets. The valve covers are not pressurized, so even if you did have high pressure, it wouldn't cause them to leak.
    Did you do an oil change since you bought it? Probably had old crappy oil in there, and now it feels better.
    Sep 2009
    BC, Canada
    Thank you for the information. I hate the used truck fears. I am always worried about every noise, leak and odd feeling when I first buy a truck, as my dad says you are buying somebody's problems when you buy used. Once she is not dripping I will be happy.
    Chevymomma,
    1993 Suburban K1500
    Formerly owned
    1985 s15 Blazer
    2002 Cavalier
    2000 Venture
Similar Threads
  1. Replies: 8
    Last Post: 02-23-2010, 09:13 PM
  2. High temp and oil pressure
    By i_build in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-28-2009, 08:51 AM
  3. High Oil Pressure?
    By DaveyBoyo in forum General Chevy Tech Q&A
    Last Post: 05-12-2009, 09:25 PM
  4. High Oil Pressure
    By dsmcfarlane in forum General Chevy Tech Q&A
    Last Post: 05-07-2009, 03:28 PM
  5. 93 Chevrolet Suburban High Oil Pressure !!!
    By Mercenary in forum Powertrain
    Last Post: 10-06-2008, 06:28 PM
