    Jr. Mechanic blackburb's Avatar
    Nov 2008
    In Da U.P. of MI - - M Go Blue!
    Default Did I do something wrong??
    I put new shocks on my '94 Burb. Now it rattles every time I hit a bump. Where there bushings in the old shocks I needed to reuse? If I grab the upper part of the shock, I can twist it just enough to make a clacking sound as it hits the mounting bolt. What's wrong here? Shocks are Monroe Gas Magnum and they didn't include any hardware at all.
    Ok, I think I may have it figured out. Seems you need to really crank the mounting bolts hard enough to bend the bracket in on the shock. Then it doesn't rattle. Is this right?
    I would think you need to reuse the factory bushings, I wouldnt want to bend something up that is holding something so vital to the vehicle
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Nov 2008
    I don't know if there were bushings. I threw the old shocks away.
    tryy making some makeshift bushings out of an old mudflap or something like that and see if that works.
    You need to tighten the bolt enough to clamp the bracket tight to the tube inside the bushing.
    Nov 2008
    Quote Originally Posted by 2COR517 View Post
    Thanks - that's what I did now. I didn't think there was any other bushings involved.
    Had the same problem. got rit of the mertic bolts. Went with standard bolts . And used washer on inside takes up space. hope this works for you. It did me.
    Washers inside the bracket are a good idea if you have that much space.
  1. Could there be something wrong?
    By 1slols1 in forum Performance & Fuel
    Last: 11-30-2009, 05:58 PM
  2. How wrong was I?
    By Kady in forum GM Powertrain
    Last: 03-17-2009, 09:09 PM
  3. What could be wrong with my 4x4
    By mike54 in forum GM Powertrain
    Last: 12-22-2008, 08:41 PM
  4. wrong oil
    By billw in forum General Chevy & GM Tech Questions
    Last: 03-09-2008, 11:31 AM
  5. what am i doing wrong?
    By 89suburban350 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-21-2007, 02:14 PM
