    Default O2 Sensor Heater Circuit Malfunction
    Got this error code today for bank 2 sensor 2. Which 02 sensor is bank 2 sensor 2 on a 1998 silverado 5.7 3 door? Anyone know what causes this error? Thanks I have inspection Friday and need to get this fixed.
    Quote Originally Posted by campuscop2003 View Post
    Here's a diagram. The code sets when the computer sees the sensor is not heating. When the sensor is heating the voltage should drop to zero. It's not uncommon for these sensors to burn out but check the fuses and connections before you replace the sensor. A good scanner that shows data would be a big help as you could watch the data feedback and voltage feedback to the PCM.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    sensor 1 bank 1 = left side before cat
    sensor 1 bank 2 = right side before cat
    sensor 2 bank 1 = left side after cat
    sensor 2 bank 2= right side after cat
    o2 sensors start to go out at around 75k, u might as well just replace it. they run around $90 and are very simple to remove. just unplug and unscrew it from the exaust pipe, i recommend you get an o2 sensor socket as they are very worth the money
  1. Power Door Lock Malfunction?
    By jdcsail in forum General Chevy & GM Tech Questions
    Last: 07-15-2010, 01:26 PM
  2. Power window malfunction
    By Straightshooter in forum General Chevy & GM Tech Questions
    Last: 08-28-2009, 03:38 PM
  3. P0332 Knock Sensor 2 Circuit Low Bank 2....03' Suburban
    By SoundZman in forum Performance & Fuel
    Last: 06-08-2009, 06:44 PM
  4. P0405 EGR Sensor A Circuit Low
    By dmbaero in forum GM Powertrain
    Last: 12-07-2008, 05:18 AM
  5. a rant of my own (circuit city)
    By 89suburban350 in forum The Coffee Shop ~ Chit Chat
    Last: 08-22-2007, 03:55 PM
