Im the the proud new owner of a 99 silv 4x4 z71. Its my first truck so please bare with me here.
How big of a tire can put on the stock 16" wheel? Ive also read around and seen mention of "leveling" kits. What exactly is a levling kit and its purpose? Is it something required if larger tires are installed?
Any feedback appreciated...
raises up the front of the truck to be level with the back, i think you can put a 285 70 r 16 on it but i am not certain someone else will chime in shortly. you can also check out the sticky at the top of this forum that tells you how much lift is needed to fit each size tire.
2004 Silverado 1500 2wd Ext. Cab
probably a 285 is a little too wide for your stock rim, but it will fit, it will just wear more un evenly, you just gotta check your clearance for the tires leveling kit gets rid of sag in front ^ what he said...
2000 Chevy Silverado 2500 4x4
6.0L v84L80E
2.5 in Daystar leveling keys
285/75/16s BFG ATs on HD wheels
Cab lights and tool box
ok thats what Ive been reading about the tire sizes. as far as raising the front of the truck level with the rear, is that just something similar to a lift kit just not as extreme?
thanks for the help and quick relpies btw..
Yeah well i put one in my truck cuz its 2wd, most 2wd are lower on the front, but now the newer 4wd are lower so they also need leveling kits, but 4wd can also just crank up torsion keys, it is a cheaper way to lift up the front, i had to do a combo of a lift and level on mine to get my tire size, but it depends on vehicle what height you need to raise so sometimes all people need are leveling kits
6.0L v84L80E
I have a 2002 silverado, the tires that came with my truck when i bought it were 285/75r16 Good Year Wrangler, they fit, but bulged in the middle a little bit, not bad just barely, just keep an eye on your tir pressure. And for a lift, you might be looking at a body lift for around $300 for a 3" body lift, I suggest getting either a Leveling kit or a Suspension lift though. BDS Suspension lift, or body lift.
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
I have the Pro Comp leveling kit on mine gained 2.5" of lift, got mine from:
http://www.stylintrucks.com/parts.as...tfamilyid=5576
they have them on sale for $150+I paid $170 for mine!
Adam
2005 Z71 Silverado Crew Cab
previous:
'97 Chevy Suburban LT
'94 GMC Sierra SLE
Bookmarks
