Well guys, today I got my headers installed. They are Pacesetter shorty headers. It wasn't a bad install at all, very simple, just time consuming and some patience for bolts. The sound is much different than what the truck was before. She sounds more throaty. I will post a vid soon of the sound with the headers, with a comparison to before. Hopefully I can see some cash back in my wallet in gas mileage out of them. That we will see.
2003 chevy impala base- 170k miles. picked up for 1000 bux
Sold :( '93 Silverado K1500, extended cab, 3" body lift, true duals, 3"X14" Polished Stainless tips, no cats, Pacesetter Headers, dynomax muffler, diamond plate toolbox with 3' CB whips on both sides, Clear headlights and directionals- sold with 140k
do you have a check engine light on due to not havin cats?im wantin to get rid of mine but that little light is gonna drive me crazy
-Dylan
2004 Silverado 4x4
4.8L
1986 K5 Blazer
8" Superlift w/39.5 super swampers
1992 GMC Jimmy "Blue Bomber"
4.3L Vortec
To solve the check engine light, you can buy O2 Simulators that act like the O2 Sensors
2002 Chevrolet Silverado 1500 z71
6.5" BDS Suspension Lift Key'd to 9"
5.5" Lift Springs with 4" Blocks
35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
Innovate LC-1 Wideband o2 Sensor x2
BDS Dual Steering Stabilizers
Electric Fan
4.56 Gears
EFI Live
thats the bad thing on new chevs i bought a computer for my that tells me whats wrong with it when lights pop up you can get a cheap one for about 100 bucks
my lights on. but still cant figure out whats wrong.? maybe just a short?
redneckarmymp, If you remove your cats the checklight will come on. You shouldhave a custom tune when you remove cats as the exhaust outflows the stock ecm capabilities and even the capabilities of most standard programmers. The O2 simulaters just turn off the light, but does nothing or the tune. Your truck will loose power without the custom tune. Also the custom tune can turn off the check light. The Dyno doesnt lie, without cats and no custom tune you loose power. Alot of people think ther truck is faster without cats because it sounds louder or there old cat was bad. I run JBA shorties with magnaflow highflow cats that are 1/4 larger in diameter thanstock cats and a larger Y pipe with a magnaflow catback. If I had it to do over I would get Dynatech longtubes with there high flow cats. This setup is good for 17hp. on a 5.3 with STOCK catback. A few years back the recieved a award from GM at SEMA for this setup.
thanks ill keep that in mind then.ive shopped around for the simulators and couldnt even find any.i removed the cats on my dodge and just ran headers and it ran sooo much better so i was wanting a similar setup on the chevy(but with pipes this time, the dodge was wayyyyy to loud).any suggestions on a good custom tune?
-Dylan
2004 Silverado 4x4
4.8L
1986 K5 Blazer
4.3L Vortec
useful sources here
Hey redneck!! I know this will go against what truck guys are about, but go through some tuner mags or website to find the O2 simulators, they seem easier to find that way. Google, "J-Body" there are some great jbody sites and these guys can point you in the right direction. (jbody is cavaliers and sunfires) so at least its staying within GM
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
...or dont waste money on the sims and just weld a couple bungs along the pipe...
that rug really tied the room together, man.
i am the walrus. shut up donny.
Bookmarks
