Does anyone have a 1500HD that has the tire pressure sticker still on it? I am looking for tire pressure info, thanks, Henry.
07 2500HD Duramax , 4DR and 26 Prowler 5th wheel Travel trailer, 57 Chev wagon with 14' Bonair travel trailer, and 71 Nova. ChevyTalk.org Canadian Regional Coordinator
are your tires load range E? if they are then 80 psi in the back and 55 psi in the front. that is what my 2500hd says on its sticker, ur 1500hd shouldnt be any different.
2004 Chevy Silverado 2500HD
6.0L Vortec
Magnaflow 4" Dual Exhaust
Leveling Kit
Westin step bars
Penda Skid Resistor bed liner
dark blue metallic
Bak Industries plastic bed rail caps
Alpine 6 1/2" SPS-600 in front
Alpine 6 1/2" SPG-17C2 in rear
Bilstein HD Shocks front and rear
Goodyear Wrangler Duratracs LT265/75/R16
Access Lorado Roll-up soft tonneau cover
Post 11. You should weigh your truck with and without the trailer. With the weight distributing hitch, you are going to need to up the fronts.
http://www.gmtruckclub.com/forum/sho...ressure&page=2
Thanks for the info on my tire inflation request. The tires are 245 LT's and E rating. I tow a 26 FT 5th wheel travel trailer and have been given different pressures by even the dealer. I have been running 55 all around not towing and 55 front and 75 rear. I just had new tires put on and the shop put in 36 all around, so I put in 45 to start, and other suggestions will be appreciated, Thanks, Henry.
I run my fronts around 40-45, rears 30-35. You're going to be much happier with those lower pressures. Truck will ride nicer, handle better, and tires will last longer.
I don't know what your pin weight is, but I'm guessing it's not to bad for a fairly small trailer. Maybe 1000-1200 lbs. I'd put the rears up around 50 when hauling, and the fronts about the same. Good luck.
Bookmarks
