    Nov 2008
    loudoun county va
    Default 2003 z71 Rear Brakes
    I failed a Virginia safety inspection due to the parking brake and rear rotor thickness.
    I thought I'd write up a small summary of replacing these.
    Rotors from Napa were $52 apiece, pads were $75 from Advance (Thermo-quiet has a
    $15 rebate) and park brake pads were $75 from Napa.
    Follow safety guidelines (chock tires, safety jack).
    Remove tire, use a 12mm 6pt socket to remove the caliper. I found it was better placed
    and out of the way wedging it in front of the rear shock rather than tying up. Yea I know
    not to stress the brake line. Remove the caliper housing using a 18mm 6pt socket. This
    took a $3 18 inch long 1 inch pipe from Lowes to break them loose. Remove the rotor clips
    (perforated washers slipped over the lug threads, 2 of them). Remove the rotor. Remove the
    parking brake clip from the inside of the park brake pad (8mm I think). Rotate the pb pad over
    the axle hub and pull outward gently and it slips off. Reverse process for installation of new pads
    and rotor. I used throttle body cleaner on the new rotors to get the packing oil off. In reflection
    I wish I used my torque wrench but I didn't have it with me. The left and right side pb pads are inverted.
    No problem one is just upside down. The rotor pads came with shims but I didn't have any installed
    when I replaced them so I didn't use them. I'm sure someone here can correct me. So far no problems.
    Legend unplugged's Avatar
    Sep 2006
    High Deserts of SoCal
    Nice. I copied it over to the "write up" section so others can benefit from your work. Thx
    High Desert SoCal
    02 Honda Civic LX
    Nov 2008
    loudoun county va
    Default more info
    I should have mentioned compressing the brake pistons which i used a c-clamp and block of wood.
    I think the use of a torque wrench would be better. I don't have the proper torque required though.
  1. 2003 z71 Rear Brakes
    By gaborn73 in forum How-to Guides
    Last Post: 09-23-2009, 11:11 PM
  2. 2003 Tahoe - rear shocks and brakes
    By Saleen2005#14c in forum Lifted & Offroad Suspension
    Last Post: 04-03-2009, 08:16 AM
  3. which rear brakes for my truck?
    By navyeoseabee in forum Lifted & Offroad Suspension
    Last Post: 01-01-2009, 08:39 PM
  4. 01 rear brakes
    By vncj96 in forum Lifted & Offroad Suspension
    Last Post: 11-12-2008, 03:07 PM
  5. rear disc brakes for a 98 Z71
    By f9108 in forum Lifted & Offroad Suspension
    Last Post: 12-30-2007, 07:01 PM
