I have a 2003 Chevy Tahoe with about 96K on it. Every once in a while (mostly when shortly after I start driving in the morning) the oil pressure guage will fall to nearly its lowest reading and the car loses power for a moment. I let off the accelorator and the pressure jumps back up and things work fine. Please note, the oil pressure guage always reads all the way right to the highest mark (I think 80). I've checked levels, fine. No leaks. Everything else works fine. Makes me think it may be an oil pressure switch. Any thoughts? Are these fairly easy to replace?
Thanks so much.
hi yes i would replace the oil pressure switch.it should be pretty easy. may be a gauge thing to. ralph
http://s1191.photobucket.com/albums/z477/noell1947/pbr%20time/
2004 Chevy Colorado 2wd/4l60e/3.5 Inline 5
6-PIAA 520 series yellow ion spot lights 85 watts each
PIAA quattro fog lights w/extreme white/yellow ion bulbs
Anzo projector headlights/LED turn signals
LED underbodys 7-color/LED interior lighting
JET stage 2 performance chip/Magnaflow exhaust S/S
Recon Big Rig Lights/LED tail lights/3rd brake light
Putco LED bed lights/BEDRUG
Goodmark 2" rise Cowl hood/K&N fipk intake
98-04' Blazer overhead console & floor console
40/60/40 seat modified to 40/console/40
33" Cooper Discovery A/T
16" Pro Comp extreme alloy wheels
It sounds like you have a voltage problem rather than an oil pressure problem. Your ignition switch may be at fault or it may be something else. Start by cleaning your battery cables. Then monitor the voltage at the instrument panel fuse while this problem occurs. If the voltage drops to the instrument panel it's a sure sign the ignition switch is going south. The voltage should remain above 13 volts with the engine running.
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
Bookmarks
