Results 1 to 10 of 13
    Default 09 gmc 2500 4x4 front end
    hi,
    I have a 2009 gmc 2500 4x4 that i want to put a plow on. I know the trucks sit low already in the front end. what is a good remedy to raise / lift the front end in anticipation for the plow?
    Frank L
    Well I take it you have a gas motor? I have a deisel in mine and what i did was add a set of Timbren's (found here: http://www.centralparts.com/Accessor...spension-Kits/) and then I turned my torsion bars up about 6 turns. You should only have to go about 4 turns the D-max engine weighs about 450 pounds more than the gas motor. This all depends on how heavy your plow is and how high you put the mount on the front end. I would definitely get the Timbren's.
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Another option is a Leveling Kit, it should raise the front end with new torsion keys, 2"-3" depending on the leveling kit you get.
    www.youtube.com/ippielb
    Legend cascott325's Avatar
    Aug 2008
    Lawrenceburg, Kentucky
    stiffer shocks/struts/springs?
    2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
    extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
    reman tranny @ 130k miles
    Chris
    Must have the Timbren!! This is the first thing you need. Maybe the only thing you need to buy.
    +1 for the leveling kit
    Quote Originally Posted by 1st Synthetics View Post
    I strongly agree. My brother put a set on his 05 and it made a world of difference.
    1973 Chevy Nova Drag Car 10.34 @ 128-Still not fast enough!
    2008 Chevy Silverado LT Z71-Sold
    2006 Chevy Trailblazer LT-Sold
    A level kit will not help with the weight of the plow. GM's need help in the front for plows. You may also want to look at welding some triangle braces behind the upper control arm. There have been a lot of broken frames on GM's from plowing. They use to have this on older models but not the new ones. I have mine cut and ready to weld on. As soon as I get to it I will post some pictures for you.
    Default timbrens
    after you put timbrens on and tighten bars would you need a front alighment?
    the level kit wont do anything for the plow weight. The timbrens would be good or look at www.firestoneindustrial.com for a set of front airsprings. then you can adjust the height with or without the plow.
    David
    1960 Land Rover Series II 88
    2001 Pontiac Sunfire
    NRA Life Member
  1. MBRP FRONT PIPE chevrolet SILVERADO 2500 HD part 2006
    Last: 07-11-2010, 11:40 PM
  2. SILVERADO 2500 2WD 04 Brake Rotors PREMIUM FRONT
    Last: 05-24-2010, 07:00 PM
  3. 2000 silverado 2500 front end shake
    By red rocket silverado in forum General Chevy & GM Tech Questions
    Last: 04-03-2010, 08:20 PM
  4. MBRP FRONT PIPE chevrolet SILVERADO 2500 HD part 2007
    Last: 01-31-2010, 11:40 PM
  5. 2500 HD Front End
    By kbuss in forum Chevy Truck Accessories
    Last: 10-21-2009, 08:13 PM
