Results 1 to 7 of 7
    Newbie 03slowverado is a glorious beacon of light
    Sep 2009
    Default Fouling out plugs
    Ive got a cammed 5.3L with a custom air intake and when i swapped in new plugs i realized that all the plugs on the passenger side were being fouled out. Even when I put in the new plugs it would kill them too, any suggestions. Thanx
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    First read the computer for any stored codes.
    When you say cammed whats the lift and duration?
    Could the grind be to much?
    Custom air intake?
    Has the computer been tuned for any of this?
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Sep 2009
    Well the cams been in since '04 so i cudnt tell u the lift or duration, but it used to run great. And no tuning has been done. The "custom intake" is just 4" pvc I modified to fit from the air box to the TB, nothing major. I was kind of thinking the problem lies in the fuel system. Maybe a fuel pressure regulator or injectors. Its just strange to me because its ONLY on the one side.
    Mar 2007
    1 Post(s)
    1 Thread(s)
    How long have you had the custom air intake on, could it be a combination of the cam and intake?
    Also have you done a diagnosic on the computer to see if it has any issues?
    The fuel pressure regulator is in line and would affect all cylinders and injectors.
    I'm thinking something in the systems telling the injectors to squirt more fuel or the injectors coul be dirty and not closing all the way allowing excess fuel in the cylinder at the wrong time.
    Tim
    2008 HHR LT
    1993 Jeep Wrangler
  5. #5
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    If you want to throw parts at it, start at the O2 sensors. The engine controls mixture for either side as a group. So if pass side reads lean, it will add more fuel to all of them. Just primary O2 sensors, the rears have nothing to do with fuel management. O2 sensors can "wear out" over time, and should be considered tune up items and replaced every 60-75K. And since it's been running rich, it's probably even more gunked up and ready for a change. Also, make sure you do not have any exhaust leaks. They can cause a false lean to the O2 sensor, which would have the same results.
  6. #6
    Newbie Rocketman540 is a glorious beacon of light
    Oct 2009
    03 slow. If you have a scanner it would be helpful to know the short term and long term fuel trim numbers.
    • Verify o2 are switching ok.
    • Somtimes a dirty mass air flow sensor will skew readings as well, you can contaminate them if you over oil the air filter, but they can be claned with some electrical contact cleaner.
    • Make sure the plugs are gapped correctly
    • Check for codes.
  7. #7
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    When you say fouling what do you mean, they are just blackend or are the electrodes getting burnt down. I had the same thing and it was a bad valve. Result was rebuilt both heads.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
Similar Threads
  1. e3 PLUGS
    By bigdaddy77084 in forum General Chevy Tech Q&A
    Last Post: 02-20-2010, 08:52 AM
  2. 99 Tahoe - #3 Spark Plug Keeps Fouling
    By Smartin in forum Powertrain
    Last Post: 12-20-2009, 10:25 PM
  3. What are these two plugs?
    By Big6ft6 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-23-2008, 11:10 AM
  4. NGK plugs?
    By rjevans33 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-30-2008, 01:16 AM
  5. Chamion "Truck Plugs" Spark PLugs
    By 4x4_only in forum Performance & Fuel
    Last Post: 08-12-2008, 09:58 AM
