Results 1 to 8 of 8
    Newbie metalchevy12404 is a glorious beacon of light
    Sep 2009
    Unhappy need help.....!!!!
    Heres the thing, my truck is a 2006 silverado LS 2 crew cab.. dont get me wrong i love this truck, but since January of this year, i've had to replace the fuel pump four times... this time with the Delphi OEM pump??? its always the same thing.. fuel level sensor doesn't read the fuel level at all, it stays at empty, and occasionally will jump to full, even when the tank isn't full....
    Master Mechanic redneckarmyMP is a glorious beacon of light
    Apr 2009
    Owens Cross Roads, Alabama
    i think sombody on here said that would be a problem with the sending unit when your sensor doesnt read properly.i could be wrong though but may be somthing to look into.is the pump going out when the tank runs dry?
    -Dylan
    2004 Silverado 4x4
    4.8L
    1986 K5 Blazer
    8" Superlift w/39.5 super swampers
    1992 GMC Jimmy "Blue Bomber"
    4.3L Vortec
    Sep 2009
    actually the pump works really good, sends gasoline even if its dry, but the level sensor is always faulty, i don't know if its a coincidence, but 4 times in a row?? like i said before the pump in the truck is the oem that i just bought, and it came up with the same problem..
    Apr 2009
    well i may be off on this and im sure sombody will correct me but from what i understand the gasoline also helps to keep the pump cool as it pumps.if the sending unit which controls the fuel level guage is faulty it may be allowing the tank to run low enough to the point that the pump is not cooling properly and causing it to go out.from what i hear these trucks are bad about that kinda thing.i know its happened to a friends avalanche last year
    -Dylan
    2004 Silverado 4x4
    4.8L
    1986 K5 Blazer
    4.3L Vortec
  5. #5
    Legend Mean_Green_95 is a glorious beacon of light
    Apr 2009
    Baton Rouge, Louisiana, United States
    redneck is correct. The gas is what cools the fuel pump, and letting the tank get a little past 1/2 is ok, but after 3/4 you are really running a big risk of pump failure. You might want to check the wiring from the sending unit to where ever it goes as it might be pinched or chaffed. Then the next step would to be check the cluster, or replace the cluster, b/c I seriously doubt that 3 new sending units would be defective.
    2000 Sierra ext. cab
    5.3, auto, power everything, Pioneer AVH-2300DVD, Kenwood door speakers, 2-10" MA Audio subs, eBay cai, 1 chamber eBay muffler exiting before tire, 245/75 16 Wrangler Armortracs, 6500k HIDs with relay kit
    1995 Cheyenne C1500 ext. cab(my baby, my first truck)
    5.0, 5 speed, Silverado appearance package, power nothing, bucket seats and console Silverado, painted black interior, eBay halo headlights, eBay chrome tails, eBay cai, dual Flowmaster 40's w/no cats, 15x7 American Racing Hopsters, Walmart fog lights, SS mirrors
  6. #6
    Newbie amorgan014 is a glorious beacon of light
    Sep 2009
    Birdsboro, PA
    as mean green said, its doubtful that all 3 sending units are bad. I worked for a Chevy dealer in the parts dept and we ran into this problem many times. it ended up being either the sending unit, or the cluster. we had to order the clusters from a supplier other than GM and had them program the mileage or we had to do it with the tech 2.
  7. #7
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    I am guessing the cluster, they can test it at the dealership, when you know that the tank is full and its reading empty is when you need to bring it in, so they can see first hand, and then you know its giving them the problem intead of them saying "we couldnt duplicate the malfunction" but here is a 120 bill for tryin go test it.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  8. #8
    Sep 2009
    thanks guys, i will check into this.
