    Default 100w driving light
    so i ordered 100w xenon driving high and low beam lights, because i have all blacked out lights on my chevy now.. has any one had these or similar lights are they alot brighter i know stock lights are 55w soo 45 more watts shold make a difference right?
    Brock Jones
    I personally would reconsider, save up and buy HIDs. I have 80w/100w in my '70 c10 and have to run a relay to prevent the extra wattage from wearing out my headlight switch. On my '09 silverado i have HIDs for my lows and fog lights. Both of witch are rated at 55w and emit far more light that is tons clearer.
    The main reason why I would reconsider the higher wattage bulbs over HIDs, is well the wattage. This extra wattage creates a bigger load on the switch, an increase in load is an increase of heat. In electrical components, heat is detrimental. To figure out your load/current draw (amps) use the equation: Wattage/voltage= Amperes. So with your 100w on a 12 volt system, you have a current draw of 8.33 Amps. Compared to 4.6 Amps with a 55w bulb or 55w HID system.
    By no means am I trying to lecture you, your trust is well your truck. But as a consumer and a truck owner, I always want to know the ins and outs of what I am about to put in or on my truck.
    To answer your question, Yes you will see a great deal of difference in brightness compared to a 55w bulb despite your blacked out headlights. Just be cautious of your light switch as it may wear out any time and possibly leave you stranded at night.
    Good luck.
    wow great info,so is there a way to maybe hook a relay into the system? and where about is the head light switch at?
    yes there is a way to upgrade your harness. The way to do this is to simply disconnect your factory harness from your bulbs, and plug it into this upgraded harness that is relayed. The relays simply bypass current draw from your factory harness and draw directly from your battery. The factory harness is still used, but simply for an actuator for the relay, telling when to turn on the lights, low beams, high beams. Since the draw will come straight from the battery, you will have to connect a positve from the relays to the battery, and also a solid ground. Sounds very technical, but i assure you its not. Its what i have on my '70.
    The link to the harness is
    http://www.summitracing.com/parts/PRF-30817/
    Note, that this is not the only avaliable harness out there. This is just one from a reputable supplier and a great company. Another one i found is the following one, as I am not too sure about, though for 25 bucks is not to hard to try.
    http://www.classicindustries.com/con...rchCatalogId=4
    Good luck
    man your awesome thanks
    No problem man, glad I can be of some assistance.
    Too bad I was not back in California with a pair of HIDs. I'd swap out my old harness, send it to you after the install of my HIDs.
    dude that would be the coolest thing... thanks again.. i like the idea of the 25 $ one haha
  1. when you driving what.....???
    By shadowt_t in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last: 03-06-2010, 09:33 AM
  2. fog light/ driving light bypass?
    By jeffz0rz in forum GM Electrical Tech
    Last: 02-23-2010, 07:03 AM
  3. ABS Light and Parking Brake Light Come on during driving
    By truckin in forum Lifted & Offroad Suspension
    Last: 07-16-2009, 08:48 PM
  4. Icy Driving
    By dwill3015 in forum The Coffee Shop ~ Chit Chat
    Last: 12-29-2008, 02:04 AM
  5. So i was driving the other day and....
    By 89suburban350 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 11-21-2007, 10:42 PM
