Results 1 to 10 of 11
    Default DANG electric seat
    '03 Tahoe
    My driver seat just stopped, of corse not where I need it, the dealer says there's no manual override (that's smart). Any ideas on getting this to move so I can drive this thing a bit safer until it's fixed? Thanks
    Newbie
    Apr 2006
    Vancouver B.C.
    That just happened to my 03 Tahoe.
    If yours is equipp'd as mine.....power memory seats, heated seats...etc , then you will have a control module under the driver's seat.
    What happened to mine was the electrical connection at the underside of the seat was melted. There is a main power feed and ground feed....right next to each other, (another GM brilliant move) and the ground wire melts inside the plug and looses contact.
    The result of non functioning power driver's seat and both front seatheaters. The passenger power seat works fine.
    To fix the problem:
    Reach under the seat at the plug and move the wires around while someone holds the power seat switch forward and the seat should move up and you can see the plug and wires.
    Next unplug the seat wiring from the floor wiring and look at the plug..(mine was black inside)....
    what I did was cut the red and black feed wires(the thick 10gauge wires)and made a new connector and joined them up by adding some wire to each and soldering them in place.
    Now it works fine...however, if yours still doesn't work after doing this, its possible that the power seat control module has blown.
    Hope this helps
    Take care
    Steve Vancouver B.C.
    2003 Chevy Tahoe
    2002 Oldsmobile Bravada
    Hey Steve ( Tazman), thanks for posting your repair---I was able to google the problem, find you post and fix my '04 Chevy 3500 in less than a hour. Nice to be able to move the seat again! My black wire was nuked in the connector, cut the ends off, spliced in a new piece and all working again. Appreciate it, buddy!
    Apr 2011
    Thornton, Colorado, United States
    Thanks Tazman! I just "fixed" my '07 burb by pushing on the connector. If it comes back I'll look for a damaged wire.
    Alan
    2010 GMC Sierra SLT
    2007 Chevy Suburban LTZ 4WD, aka BB
    Thanks Steve, it was 1 wire in the connector that came loose, don't know how. I ended up taking it to the dealer yesterday afternoon and after 150 in labor and 18 for 'shop parts' it was fixed. But I'm glad to see your post, if it ever happens again I'll remember what you said and give it a try.
    Wow, sorry to hear about your problem from just one wire. Happy to know that they fixed it though.
    For the want of a nail, the Tahoe was lost...
    Steve
    10 Chevy Traverse LT AWD
    Edmonton Alberta
    Default Dang Electric Seat
    Thanks for your post. Luckily I only had a loose connection. Problem solved and no trip to the dealer.
    Bentley
    I have a 2003 Tahoe and both heated seats are not working. When you press the heated seat button, the lights come on but when you let go of the button, the lights go out. This is for both sides, driver and passenger this is occuring. Any idea what the problem maybe? Please email me at ohhellnaw@gmail.com
    Edmonton Alberta
    Sounds like the switch is nuked. If the lights come on when you press the button, there must be power at least to the switch. You could remove the door panel and test the output side.
    I've had two issues with the seats in my Silverado. 1st was the connector under the seat. It can easily be bumped and then you lose all power to the seats. 2nd problem occured when a wire had broken off in the door bellows. This problem was off and on as the wire made contact intermittenly. Patched that up and end of problem.
    Haven't had any issues with my Tahoe but it's a bit older (2000).
    Bentley
    1986 GMC 2500
    1998 GMC Jimmy 1500
    1996 Silverado 1500
    2000 Tahoe (current)
    2004 Silverado 3500 (current)
    2011 GMC Yukon Denali (current)
    I also have problems with my seat heater on the drivers seat in my 03 Avalanche, it turns on and starts to get warm and shuts off. The passenger side is fine, I have had problems before and my breaker was bad, but everything quit when it went bad. I guess I will have to check my wiring under the seat. I already checked everything in the door and its all good.
    As long as the passenger side works so I don't have to listen to the whining that the seat is cold, it's all good!
    Ford has a better idea! Drive a GM!
    07 GMC Sierra Classic
    07 Honda Accord EX-L
    68 Camaro (blown)
    2011 Ford F550 V10
    I don't own this truck, I just drive it!
  1. Electric seat override
    By alleycat37 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 07-03-2010, 02:05 PM
  2. Replies: 0
    Last Post: 06-03-2010, 01:30 AM
  3. Drivers electric seat has slack
    By new2dis in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-08-2009, 11:52 AM
  4. Another Dang Accident
    By CarpenterGuy in forum The Coffee Shop ~ Chit Chat
    Last Post: 06-19-2009, 10:31 AM
  5. Dang on brakes I think
    By 04Avalanche in forum General Chevy & GM Tech Questions
    Last Post: 04-30-2009, 02:11 PM
