Results 1 to 2 of 2
Thread: A/C Problem
    Default A/C Problem
    Got an A/C issue on my recently bought '99 Tahoe (5.7). While looking it over I noticed a green stain on top of the A/C compressor. Didn't think much of it until I noticed the A/C wasn't cooling as well as it should. Took another look and on top of the compressor there are two black screw caps on the front and left sides of what I assume is some type of coolant valve. (R-134a conversion maybe?) The front fitting appears to be leaking a bit under the cap. Never worked on A/C equipment before and really don't want to with all the high-pressure fittings and stuff. Easy fix or new compressor?
    Aug 2005
    North Central Texas
    Default A/C compressor
    I'd say go and get a new compressor, unless you've got some serious skills when it comes to A/C repair. I own a 95 tahoe and the A/C compressor is a peice of junk so when it goes out (which it has twice in two years) I just go and have the dealership replace it. basically what you have to do to fix it is: 1, let all of the coolant out of your lines; 2, diconnect the compressor; 3, rebuild the compressor or replace it; 4,blow all of the crap out of the coolant lines (I guess they do that with compressed air); 5, reconnect the compressor; 6, refill all of your coolant lines; and my favorite, 7, test it all out by running the A/C and hope that you dont spring a leak or blow up the compressor.
    now I've never actually done this so I couldn't exactly guide you through the process. But if I were you, I'd just get the thing replaced and get a warranty on the new one, so that way if you have any problems with the new one, getting it fixed is free (except for labor costs of course).
  1. ABS problem
    By FireRed in forum Lifted & Offroad Suspension
    Last Post: 01-09-2010, 09:57 AM
  2. 96 Chevy tahoe problem fuel problem? Need help ASAP!
    By Fear58 in forum General Chevy & GM Tech Questions
    Last Post: 12-13-2009, 05:38 PM
  3. new here but have a problem
    By kjames323 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-06-2009, 07:41 PM
  4. A/C problem
    By mprodman in forum General Chevy & GM Tech Questions
    Last Post: 04-03-2009, 12:41 PM
  5. Problem with AC
    By 4runnerGuy in forum General Chevy & GM Tech Questions
    Last Post: 03-30-2009, 07:10 PM
