    Default Rounded off transmission drain plug bolt
    Hi All,
    I rounded off the drain plug on my transmission pan drain plug (2003 Yukon XL).
    I've heard this is not an uncommon problem--apparently they overtighten them at the factory and then when you try to get them off, the bolt just rounds off? Well, whether it's true or not, both I and a friend of mine had the same experience, so we now need to use a bolt extractor to get it out of the pan.
    I'm wondering if any others here have had experience with getting a frozen (and rounded off) transmission drain plug out, and if so, what extractor kit/method have you had the most success with?
    -Josh
    Josh,
    the easy way to do this is to pull the pan. The plug will come out on the bench with a little heat and some vice grips. If not it's a good excuse to buy a deep pan. <G>
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Wouldn't heat cause the bolt to lock up even more as the bolt would expand and tighten up against the threads?
    I thought that was essentially what caused pistons to freeze up--they get too hot (usually due to lack of lubrication), they expand, and then lock up inside the cylinder.
    I already have a deep pan, for whatever that's worth I see from gm parts club that a new pan will cost me about $60 plus shipping. I've toyed with the idea of just getting a new pan along with a replacement drain plug in case I totally destroy the old pan and drain plug when I take it off and try to get the plug out.
    Heat will melt the thread sealer and washer letting the plug free.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    Quote Originally Posted by Jimmiee View Post
    Ah, ok.
    By the way, what's the advantage of the deep pan over the shallow pan? The only thing I know is that my filters cost more since I have the deep pan
    Quote Originally Posted by jbeall View Post
    Ah, ok.
    The extra fluid actually cools the transmission better and with a 4X4 the deep pan allows the filter to stay submerged during side-hill operation.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  1. Radiator drain plug
    Last Post: 05-05-2011, 03:20 PM
  2. Butterfly Drain plug
    By uscs04 in forum General Chevy & GM Tech Questions
    Last Post: 11-05-2008, 12:37 PM
  3. Rounded Out TORX Bolts on the Transmission
    By Tom Evans in forum General Chevy & GM Tech Questions
    Last Post: 04-13-2008, 09:09 PM
  4. Rounded Out TORX Bolt on Transmission
    By Tom Evans in forum GM Powertrain
    Last Post: 11-26-2007, 12:11 PM
  5. coolant drain plug [Expired Topic]
    By ziggy919 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-15-2006, 05:25 PM
