I just moved up from my 01 Burban and got a 07 GMC Yukon XL 2500 w/6.0, I drove it from Huntsville AL to Chicago and was getting about 14-15 MPG, since getting it home, my mileage has dropped to 7-8 MPG. The only changes have been tire & rim upgrade (17" rims & BFG all terrains) and a brake controller for my camper. Why has the mileage dropped sooo badly???? Any suggestions on what is causing it??? I am being VERY easy on the pedal to see if the MPGs will increase, but no luck...HELP!
Are the tires the same size. Speedo could be off but that still seems like a large drop.
David
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
1999 Saturn SC1 (the new commuter car)
All tires are the same size, I dont know if I got a bad tank of gas or what????
bad gas is possible but you would be running rough too. is the 7-8 all city. I only get 12-14 highway and about 8-9 in city, and I have the 6.0. your highway mileage should be more than mine but not surprised if city is around the same.
David
If you switched from a ht tire to an at tire then thats going to be one of your biggest culprits.
2000 Sierra ext. cab
5.3, auto, power everything, Pioneer AVH-2300DVD, Kenwood door speakers, 2-10" MA Audio subs, eBay cai, 1 chamber eBay muffler exiting before tire, 245/75 16 Wrangler Armortracs, 6500k HIDs with relay kit
1995 Cheyenne C1500 ext. cab(my baby, my first truck)
5.0, 5 speed, Silverado appearance package, power nothing, bucket seats and console Silverado, painted black interior, eBay halo headlights, eBay chrome tails, eBay cai, dual Flowmaster 40's w/no cats, 15x7 American Racing Hopsters, Walmart fog lights, SS mirrors
I have a 08 silverado and I just put on 285/70/17 nitto terra grapplers and the first tank I burned with them on I got about the same gas mileage, but with the past 2 tanks I've been getting almost 90 kms a tank less is this normal.
Going from a HT to a AT tire should be very minimal MPG drop, maybe a mile per gallon but surely not 5-7
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
I would say run another tank of gas through it and see if it does the same thing. That would rule out bad gas. If it's running fine, it certainly seems like a weird problem...
Matt
Hallsville, TX
2005 Silverado 1500 LS Crew Cab 5.3L 2WD
K&N FIPK II
Magnaflow Exhaust
Hypertech Max Energy Programmer
Suspension Leveling Kit
Putco Element Window Visors
Carriage Works Billet Grille
TruXedo TruXport Tonneau Cover
I just had a big drop in mileage and also just noticed my temp gauge is way low, about 150 to 160 degrees. Don't know if it's related or not. I'll be putting in a new thermostat this week to see if that fixes both problems. I read somewhere that if the engine is running too cool, the computer will dump extra gas just like it does when first started. I'll report back.
1997 Silverado, Ext cab, 4x4, 5.7, Loaded
You thermostat might be stuck open, which wouldn't allow your engine to run at optimal temp. That might cause a decrease, along with the change in tires. Run some GM TEC in the engine or some Seafoam to clean out any carbon buildup. Carbon build will rob you of gas big time.
Bookmarks
