Results 1 to 6 of 6
    Sr. Apprentice kjb13 is a glorious beacon of light
    Jun 2009
    Bausman, PA
    Default Poor mileage - Thermostat ???
    The last few tanks seem to be really bad mileage. I just realized that my temp. gauge is reading about 160. I'm guessing the thermostat is stuck open. Could this be the reason for the bad mileage?? If so, what thermostat do you guys and gals recommend??
    Thanks,
    Kevin
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Not usually, but it depends on what you are driving.
    Give us a clue please.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Jun 2009
    Bausman, PA
    Sorry. 1997 Silverado, extended cab, 4x4, 350, auto., 110,000 miles.
    Jun 2009
    Bausman, PA
    Any ideas??
  5. #5
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Yes a non working t-stat can effect your mileage. When your engine is running cooler without the computer tuned or a programmer that can change it, it reads cooler so it dumps more fuel in, now if you had it adjusted to take that extra fuel it would be fine, but without that it just has too much fuel, I would bet you have some black smoke coning out the tailpipe.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  6. #6
    Sep 2006
    Quote Originally Posted by kjb13 View Post
    Welcome. Check out how to include info in your signature here: GMTC
    The stock temp is a 195 deg. tstat. The emission control system is temperature dependent. During the summer I run a 160 in my burb just to get a head start on the 100+ temps here in the Mojave. In the winter I'll swap out to the 195 just so she warms up for the cold mornings.
    It's cheap enough to change the tstat. You can also test it, by dropping it in a pot of boiling water. (CAUTION do not use the little woman's favorite quart sauce pan, or you may find out what a frying pan upside the head feels like.)
    I'd look into something else like a fouled plug, loose plug wire. Check for DTC codes just in case.
    And don't forget the often overlooked tire pressure.
    The engine's combustion chamber can reach temperatures of up to four thousand five hundred degrees Fahrenheit. About thirty percent of the fuel is converted into actual power, and about seventy percent is spent into heat. A cooling system protects an engine from damage by transferring heat to the atmosphere by using the radiator. A correct operating temperature is critical for the proper function of the engine. The thermostat controls when coolant is allowed to flow into the radiator and back into the engine. Manufacturers have found that a 195 degree thermostat is optimum for efficiency. Below this threshold the catalytic converter will not work to capacity and will produce increased emissions. ..............
    High Desert SoCal
    02 Honda Civic LX
Similar Threads
  1. 2002 Tahoe poor gas mileage......
    By colfrank in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 03-29-2010, 03:16 PM
  2. The right thermostat?
    By erikshunn44 in forum General Chevy Tech Q&A
    Last Post: 07-10-2009, 08:10 AM
  3. Thermostat won't fit!!!
    By sc99z71 in forum Powertrain
    Last Post: 04-01-2009, 12:46 PM
  4. Poor Gas Mileage
    By Art in forum The Coffee Shop
    Last Post: 08-14-2008, 03:41 AM
  5. poor gas mileage
    By green 1984 chev 4x4 in forum Member Introductions
    Last Post: 06-06-2008, 12:07 PM
