    Apr 2009
    Springfield, MO
    Default Odometer/gear selector lights intermittently working
    The odometer/gear selector lights on the instrument cluster appear to be going on the fritz. Sometimes they are completely off, and sometimes they work perfectly. Does anyone know of a place that repairs these things?
    I found replacement clusters on E-bay. Would that be plug and play, or would a dealer have to program it to reflect the correct mileage?
    1999 Silverado Z71 Extended Cab New body style
    I know on the 88-98 trucks the factory has to program the odometer for a new cluster, I know yours is a digital readout so I am not sure if that is stored in the computer or the cluster. The dealership can test the cluster to be sure if thats what is actually failing.
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    A bad ignition switch can cause this problem. Check the voltage at the instrument fuse when this is happening. If the voltage is below battery voltage you probably have a bad switch.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Sr. Apprentice brianj's Avatar
    Oct 2009
    New Hampshire
    It is very easy to pull these gauge clusters. Once it is out, you can replace all of the bulbs from the back of the instrument cluster.You can do it in less than an hour. I assume you are talking about the lights and not the gauges themselves? This is close to the era where they changed the dashes around, but I think this is still true on your truck,although I may be wrong.
    I have the same issue with a 2001 Suburban. It has done it twice now, I start the vehicle and the odometer readout and the gear selection indicator goes dark. I hit the trip reset button a few times and it lights back up. I'm pretty sure this is not going to get better, so a description of the resolution to this problem would be appreciated.
    I just mailed mine off to a company in Missouri to have it fixed. They replace the motors, lights, and everything for 189$ free UPS shipping. Should get it back next Monday. drspeedometer.com
    Current:
    Future:
    US Navy Sailor :sign0011:
    The cluster is going bad, you would have to take it to the dealer and have them get the part number from the cluster, order it, bring it back in and have them pull out all the info from the bad cluster, install the new one and upload all the info to the new cluster, or like previously mentioned send it off to get rebuilt, they are super simple to remove
    Friends dont let friends drive fords!
    Proud GM Technician
    Apr 2009
    Springfield, MO
    I ended up having mine fixed for 30 bucks! I simply printed out the DIY instructions and took the instructions and the instrument cluster to a local electronics repair shop, since I was not confident in my ability to DIY. Mine still works fine today. Good luck!
    Here is a link to the DIY:
    http://mrfixit.webnode.com//
    I had a similar problem with my truck last summer. My wife was driving the truck at the time and she says the entire instrument panel flickered and all the gauges went haywire for a few seconds and then everything went dead for a second and came back on like nothing had happened. I told her that's what she gets for driving my truck (lol, just kidding). Anyway, I thought it might be a loose ground so I tightened every ground I could find in the cab and under the hood and I haven't had an issue since then.
    2000 GMC Sierra Z71
    Quote Originally Posted by Cujonaut View Post
    2000 GMC Sierra Z71
    That'll do it. You can put 2000 GMC Sierra Z71 as a signature so you don't have to keep on typing it out as well as a picture
    Current:
    Future:
  1. Picture of trailer on gear selector
    By wvucoalminer in forum General Chevy & GM Tech Questions
    Last Post: 03-19-2012, 07:30 PM
  2. 1999 GMC Sierra Odometer lights
    By BBodie in forum Lighting Discussion
    Last Post: 10-19-2010, 12:19 PM
  3. Sloppy Gear Selector
    By tauchen67 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-04-2010, 07:15 AM
  4. dash lights not working
    By mxkjk2 in forum Audio, Video & Gadget Tech
    Last Post: 01-19-2009, 09:27 AM
  5. Gear Selector Stuck!
    By suarowing in forum General Chevy & GM Tech Questions
    Last Post: 01-06-2009, 11:57 PM
