Results 1 to 2 of 2
Thread: OEM fuel lines?
    Default OEM fuel lines?
    On my 1998 Suburban,
    The design of the sending unit fuel connections don't allow the classic scissor style fuel disconnect tool to be used (I have a good quality Lisle one). I had to go get some of the plastic ones at Advance this morning, the 3/8 and 5/16. Anyway, the thing just about won't go into slot because of the design of the connections, but I got it. I pulled the return line away from the sending unit, and I found that the internal spring steel ears had gotten mangled in the process. Basically, the steel spring release thing was still latched around the slot on the sending unit. I'm pretty sure you can't buy those things separately, they look like they should be made into the line.
    couple questions:
    1. Presume I probably need a new return line (up to the union fitting on the frame, midway up the [COLOR=blue !important][COLOR=blue !important]truck[/COLOR][/COLOR])?
    2. Can you insert the steel clamping ears back into the line (doubt it)?
    3. I think someone had done this job before me - the words Airtex were written across the sender and pretty sure he had fubard the steel ears before me?
    Thanks for the help
    I wish this was help, but I am trying to pull the intake off my '99 5.3L. None of the tool types I have seem to release the two lines to the fuel pressure regulator. If I learn something I will let you know. Your post is a good warning for me to use care. thanks.
    wucky
  1. Fuel lines draining when sitting?
    By riata_ag in forum GM Powertrain
    Last: 03-27-2010, 08:31 PM
  2. HELP! Rear fuel lines for an 89 TBI...nobody makes 'em
    Last: 02-27-2008, 06:11 PM
  3. air in fuel lines
    By woodbutcher in forum General Chevy & GM Tech Questions
    Last: 02-17-2008, 08:20 PM
  4. TBI fuel lines, can I use rubber??
    Last: 02-11-2008, 08:30 AM
  5. replacement fuel lines
    By theres in forum The Coffee Shop ~ Chit Chat
    Last: 09-12-2006, 02:00 PM
