Hey there guys im new to this forums but im curious to find out whether this would work out or not. First off i drive a Black '08 Z71 4x4 Silverado on 24's. I recently got the 24's but before i did that i went one last day mudding...... :(( big regret. essentially i hydrolocked my engine and finally got it fixed... had to test start and begin the process of taking all my spark plugs off and hand crank crank shaft etc etc. Well i finally got it started and realized that i snapped a cylinder rod and chevy wont cover it b/c my cold air intake isnt covered under warranty and chevy wont cover water intrusion. So i just came upon a '99 Z06 Vette. this bad bitch easily hits 240 topped out so my question is can i swap out the vette engine and put it in my silverado? i plan on making my truck street performance anyways but my friend suggested i do that and he said it would work with a couple modifications... Is this correct? I would appreciate any input in this topic. Thanks :D
wow how ironic ....
Your tranny wont handle the load, your rear end would need some upgrading to make it worth it, and you would need the computer from the vette, i am sure there is more but these are for sure. I would just rebuild your current engine. If you have the 5.3 you can hook the LS6 intake to it, some headers and a cam and then het a custom tune, then get a shift kit for your tranny
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
well what all would i need to do with it?
Mark
2007 Black Silverado LTZ Z71 4x4 Crew Cab, 5.3L, Airaid MIT and K&N Filter,
Corsa Sport Exhaust, Rough Country 2" Leveling Kit, Removed Front Air Dam,
N-Fab Steps, Line-X Bedliner, Truxedo LoPro QT, Carriage Works Billet Grill,
18x9 Helo 835 Machined Black Rims, 285/65/18 Nitto Terra Grapplers
Time to slow down on the mods! Running out of money
Yeah and the 7.0 Liter 427 wasnt until the most recent Z06.
Hypertech III
Reg Cab Long Box
Jason
2004 Silverado
4.8L
K&N Air Filter
Single in, Dual out Flowmaster look alike, Turned down at muffler
dropped 2" front 4" back
Custom painted bow ties (blue front and black back)
20" Eagle Alloy Series 026 rims
285/50-20 Good Year Eagle GT II tires
Limo Tint all around
Duraliner bed liner
i know that the 6.0l was in the c5 that was just a picture i found after posting. what all things would i have to do to my rear end and tranny?? im lost with this but i kinda wanna follow through with the engine swap....
you will definately need to beef up the transmission. Look at summit racing as they will probably carry transmissions for that may even be a 4l80/85e
David
2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
1960 Land Rover Series II 88
2002 Nissan Altima (wife's Car)
1999 Saturn SC1 (the new commuter car)
The Z06 has only carried two engines since the started using that distinction again.
GEN 1 5.7 LS6 405HP C5
GEN 2 7.0 LS7 505HP C6
Hypertech III
Reg Cab Long Box
Jason
You need:
1. Upgrade (read basically totally replace) Front end, rear end, transmission, and transfer case, because none of them will handle that kind of power.
2.upgrade the suspension, because you will be pushing the chassis beyond anything it can handle.
3.replace the brakes all the way around with much larger ones, because she wont' stop real well at over 100mph.
4.three or four mortgages on your house to pay for all this, plus someone to make all of the electronics work.
Sounds pretty cool- but way beyond anyone but a well equipped professional shop who will charge you enough to bail out the countries' trade deficit. Trust me- I have two or three projects like this that will probably never see the road unless they are being towed away.Wish I could get back the time and money I have in them.
Bookmarks
