Results 1 to 5 of 5
    Jr. Apprentice energyleech is a glorious beacon of light
    Feb 2009
    los alamitos, CA
    Arrow EATON went out!
    88 suburban 454 2wd, 3/4 ton 69k miles.....clicking noise and rough shift between 1st and 2nd gear, traced the noise back to the differential...click click click when the wheels turned, grease splattered over into the right shoe of the drum brakes ( inside)....damned if this wasnt bad timing, had no time to sit on it, had to get fixed right away, put me in a pickle! spent tooooo much to get that differential replaced, expensive part....any body else have one go out? i have heard they are real dependable and tough, but wtf? the other soulution was to just get a gasket job done and hope for the best...was I stupid to get it replaced?
    Feb 2009
    los alamitos, CA
    Default 88
    suburban 2500 1988 2wd
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    You did the right thing. If you left it alone it would have taken out your ring and pinion gears. I don't see any correlation between the differential problem and the harsh shift or the leaking axle seal however.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Feb 2009
    los alamitos, CA
    Default ok
    thanks for the reassuring words...i failed to mention that a small tubing that feeds in to the turbo 400 transmission had fallen off and was a bit rotted. no liquid coming out of it, dont know what goes thru it, but i put a new tube on it and it seems to be fine now...im not sure if the differential fixed the rough shift or this tube? what do you think?
  5. #5
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by energyleech View Post
    The tube fixed it. This is a vacuum line to your modulator. The modulator controls line pressure. With the tube rotted it will have high line pressure and shift hard all the time.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
Similar Threads
  1. Eaton G80 questions
    By nos351wcm in forum Powertrain
    Last Post: 01-17-2010, 11:16 PM
