Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jr. Apprentice Smartin is a glorious beacon of light
    Oct 2009
    St. Charles, MO
    Default 99 Tahoe - #3 Spark Plug Keeps Fouling
    I replaced the plugs, wires, dist cap, and rotor about a month ago. This past weekend, I noticed a heavy miss while under load. I asked the service manager at the dealer to check what codes it was throwing while driving. It was the #3 cylinder misfire. I pulled the spark plug and it had some heavy buildup on it. Like, stuff I had to use a screwdriver to chip off. I cleaned it up, and I don't feel the miss anymore, but I have to think that this is going to happen again.
    I replaced the coil this afternoon just for Sh!ts.
    What could be causing the #3 cylinder to continue to foul?
    Adam Martin
    1971 Buick Centurion Formal Coupe
    1958 Buick Limited Four Door Riviera
    1995 GMC Yukon Four Door 4WD
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Default Spark plug diagnosis
    Which picture does it look like?
    See the full size chart here: http://www.aa1car.com/library/reading_spark_plugs.jpg
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Oct 2009
    St. Charles, MO
    Mostly like "ash deposits"
    Someone else told me my intake gasket is probably leaking into that cylinder. Make sense?
    Adam Martin
    Sep 2006
    Quote Originally Posted by Smartin View Post
    An intake leak into that cylinder would make it run lean, which in turn would make it HOT. Search forums for vacuum leak and test to see if you do have a vacuum leak. Looks more like an oil leak or additive deposits. Try running a couple of tankfulls of Chevron gas and see if the deposits clear up. Also, a combustion chamber cleaner like seafoam or Delco's brand would be a good idea.
    High Desert SoCal
    02 Honda Civic LX
  5. #5
    Jr. Apprentice truheel1 is a glorious beacon of light
    May 2009
    Charlotte NC
    Default dead plug
    What did the old plug look like in #3 cyl??????? If it looked the same, its not something new from replacing the plugs. If it just started. Could be a dead plug from the start. I had a NEW dead plug in the golf cart would not fire. got another new plug works fine now...
  6. #6
    Oct 2009
    St. Charles, MO
    Ok guys, I finally had the symptom show up again. Pulled the plug and shots some photos....
    What do you think? I am definitely losing coolant mysteriously....not sure about oil, though. Oil consumption seems consistent with the mileage of the engine.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	4569   Click image for larger version
ID:	4570   Click image for larger version
ID:	4571   Click image for larger version
    Adam Martin
  7. #7
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    The best thing to do is a compression test of the cylinder. I had the same problem and I had to get the heads rebuilt. i had a velve taht wasnt closeing all the way.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  8. #8
    Jr. Engineer ahm1127 is a glorious beacon of light
    Jan 2009
    Pennsylvania, United States
    I would use a combustion chamber cleaner like seafoam or AC Delco's brand cleaner first. Use an oil additive to clean engine, drain & run engine 1 quart low to see if there are any changes.
    Good luck
    Aaron M. of PA
    05 Suburban, Suzuki Aerio
    90 Suburban, 00 Tahoe
  9. #9
    Jr. Apprentice jnbascom is a glorious beacon of light
    Nov 2009
    Santaquin, Utah
    Looks like you got a bad head gasket. The white deposits are from the engine coolant.
  10. #10
    Oct 2009
    St. Charles, MO
    I ran a compression test this morning to check for a head gasket failure. All cylinders checked out at around 180psi.
    I found someone who will replace the intake gasket(s) for $250 plus the cost of the gasket kit. The dealer wanted $600 WITH my fleet discount.
    He is picking it up this evening and delivering it back home tomorrow around noon. It'll be nice to have this finally fixed! Maybe I can get him to grease the slip yoke for me while he's at it....hmmmmm
    Adam Martin
Similar Threads
  1. Spark plug 41-985 replaced by 41-110
    By heiseygal in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-06-2010, 12:32 AM
  2. Spark Plug?
    By Chevyman224 in forum Performance & Fuel
    Last Post: 11-05-2009, 07:15 PM
  3. Which AC Delco Spark Plug do I need?
    By 178kchevy in forum General Chevy Tech Q&A
    Last Post: 03-17-2009, 09:01 AM
  4. What spark plug to use?
    By partsman in forum Chevy C/K Truck Forum
    Last Post: 03-09-2009, 01:58 AM
  5. Spark Plug ??
    By Blakjax98 in forum General Chevy Tech Q&A
    Last Post: 01-04-2009, 11:58 AM
