Evening, I have a 03 3/4 ton silverado with the duramax, it has been sitting for a month and not started during that time, weather has been Colorado weather, nothing below 20 overnight. SO he problem is key goes in, lights come on, engine warms up, gages work, BUT NOT the fuel gage, it stays on empty and the empty light stays on. turn the key and nothing, well the lights dim but thats all,
Fuse?
half a tank of fuel when shut down last time
any help would be greatly appreciated,,,,,,,,,,,,,,
Thanks
blco
Any trouble codes? Curious because of similar problems for 2001 - 2005 diesels. See this NHTSA info
Link to Service Bulletin
Make : CHEVROLET Model : SILVERADO Year : 2005 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Number : 050604008 Date of Bulletin : APR 01, 2005 NHTSA Item Number : 10017337 Component : ENGINE AND ENGINE COOLING:ENGINE Summary :
DIAGNOSTIC TROUBLE CODE (DTC) P1172 OR P2636, FUEL GAUGE READS EMPTY, SERVICE ENGINE SOON (SES) LIGHT ON. *TT
Also this item:
Make : CHEVROLET Model : SILVERADO Year : 2005 Manufacturer : GENERAL MOTORS CORP. Service Bulletin Number : 05539 Date of Bulletin : APR 01, 2005 NHTSA Item Number : 10017551 Component : POWER TRAIN:AUTOMATIC TRANSMISSION:CONTROL MODULE (TCM, PCM) Summary :
PRODUCT EMISSION RECALL TO REPLACE THE POWERTRAIN/ENGINE CONTROL MODULE (PCM/ECM). THE POWERTRAIN/ENGINE CONTROL MODULE (PCM/ECM) MAY HAVE BEEN MANUFACTURED WITH DAMAGED INTERNAL IC CHIPS, WHICH MAY AFFECT THE FUEL PUMP CONTROL AND EGR OUTPUTS OF THE PCM; OR THE FUEL PUMP CONTROL AND VARIABLE NOZZLE TURBO CONTROL (VNTC) OUTPUTS OF THE DIESEL ECM. *TT
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
Thanks
Not rich enough to have a code detector,
Will have to call the dealer on Monday and do the dance
blco
Bookmarks
