Results 1 to 5 of 5
Thread: Rv cam?
    Sr. Apprentice burbanguy is a glorious beacon of light
    Jul 2008
    Default Rv cam?
    I have an 87 Suburban w a 350 Tbi and I've heard of some ppl saying something using a rv cam and I was wondering what exactly they mean and is this a good mod for towing? Where can I find one of these and is it worth the time and effort? (The upgrade)
    Master Mechanic KidHauler is a name known to all
    Jan 2009
    MI
    I had one in my 75 Jimmy and loved it. I think its just a little deaper duration, to increase torque, but all that math stuff gets past me. The ol' Jimmy wasn't fast, but he was a puller!
    They sound cooler, too!
    1999 Chevy K2500 Suburban 350
    K&N, reworked cai, Thrush cat-backs
    Vinyl, cranks, floor shift, and rear air!
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    RV cams are generally a different cam grind from factory, each manufacturer has a little different lift and duration they feel works best for a given engine operated in a given situation.
    Contact some of the cam manufacturers and que them on your truck specs and how and where you operate your truck they should be able to better help you choose a cam that will work best for your situation.
    You have to be careful with aftermarket cams, you could put in something that runs great upto a certain RPM then looses all torque, or end up with something that doesnt start generating power until the RPMs are real high.
    Factory cams are a compromise in that they run well at most RPMs while returning decent fuel mileage and power.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Jul 2008
    So when ppl say rv cam, they are not meaning they took a cam out of Rv motor and swapped it into their truck? So then where can I find these rv cams and y do they call them rv cams if they don't come from an rv?
  5. #5
    Mar 2007
    1 Post(s)
    1 Thread(s)
    Heres a couple manufacturers I've used for aftermarket cams in the past.
    http://www.edelbrock.com/automotive_...chevy_sb.shtml
    compcams.com
    Tim
    2008 HHR LT
    1993 Jeep Wrangler
