Results 1 to 2 of 2
    Newbie aaronbircher is a glorious beacon of light
    Oct 2009
    Default 454 vortec cools from195 to 180
    I just replaced intake gaskets hoses and thermostat. The truck hits 195 at idel. When I take off it cools to below 180 and stays there??? can i expect troubel? why wont it hold the temp stable?
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Less air is flowing through the radiator at idle. When the truck is moving, the increased airflow and the water is circulating faster so it drops the temp. The temp will vary by engine speed, load and ambient air temperature. If you are pulling a trailer up a steep grade, you will run hotter. If it is 30 degrees outside the temp will run cooler than if it is 115 deg.
    Your truck seems to be running with its temp range so I wouldn't worry.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
Similar Threads
  1. TBI to Vortec
    By OleBlue93 in forum Performance & Fuel
    Last Post: 04-27-2010, 04:53 PM
  2. V6 Vortec?
    By Lightzz2k in forum Chevy C/K Truck Forum
    Last Post: 11-20-2009, 12:14 AM
  3. Vortec 383 What Cam to use
    By OleBlue97 in forum Performance & Fuel
    Last Post: 05-28-2009, 09:35 PM
  4. Vortec 4200 Information
    By camokid345 in forum Performance & Fuel
    Last Post: 09-26-2007, 03:41 PM
  5. Credit crunch cools demand for automobiles
    By Steve in forum Automotive News
    Last Post: 08-28-2007, 07:53 PM
