Results 1 to 7 of 7
Thread: No 4x4
    Newbie Weak66 is a glorious beacon of light
    Sep 2009
    Mountain Home Id.
    Default No 4x4
    Yesterday I found myself in a bit of a spot. I was headed back to my favorite hunting spot and it had rained the night before. I stopped before I hit the trail and put my truck (85 K-10) into 4 low and locked the hubbs to combat the ruts and slick mud. Needless to say, I got stuck. My rear tires were down in muddy ruts but my front tires were up on dryer dirt where there was plenty of traction and, if the front was pulling, should have pulled me right out. My rear tires were spinning like crazy but couldn't get the front to spin even a little. Any ideas? I'd like to do this myself and I don't know any way to check the 4x4 in town. The only way I know is to take it out to the mud and stomp the gas and see if i get all 4 to spin. Please help!
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    An easy way to check your truck is to simply jack up the rear end off the pavement. Put the truck into 4 Wheel Drive. If your front end is working it should pull you and the jack forward. Do not give it a lot of throttle when you do this. Just putting it into gear is all you need to do. Now if it wont move have someone look under the truck and see if the front drive shaft is turning. Do not leave the driver's seat with the truck in gear like this. What you will probably see is the drive shaft turning. If it is you probably have a broken hub or axle.. You will probably see one axle turning in front. The axle that is turning is the side with the broken hub or axle.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Thumbs up 4 wheel drive test video
    Here is one man's way of testing the 4wheel drive:
    [ame="http://www.youtube.com/watch?v=sKnq22t_gko"]YouTube - How to test the 4 wheel drive[/ame]
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Feb 2009
    Reno, Nevada
    That's one way to do it! LMAO!!!!!!!!!!!1111111111111
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  5. #5
    Sep 2009
    Mountain Home Id.
    After further troubleshooting I have discovered that the front drive shaft turns but no power to front tires with hubs locked. I jacked up the rear end and put it in 4x4 and the front drive shaft turned but tires as still as a sleeping baby. How can I tell if it's hubs or broken axle?
    Lars A. Wetli
    God Bless and Go Bucks!
    85 K-10
  6. #6
    Sr. Apprentice mainec is a glorious beacon of light
    Oct 2009
    Jacksonville, Florida
    Sorry guys, that is one of the dumbest videos I have ever seen.
    Charles
    2008 Chevy Silverado Z71 4x4 Crew Cab
    6" Pro Comp Suspension Lift
    20" Pro Comp Alloys
    35" Pro Comp Extreme A/T
    Flowmaster Super 40 Series Dual Exhaust
    Smitty Built Nerf Bars
    10% Window Tint
  7. #7
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by Weak66 View Post
    If you look behind the front wheels you can see the axle U joints. If one is spinning then the hub is not working and all the power is being transferred to that hub since there is no resistance there.. If neither are spinning then you might have a broken axle. To check for a broken axle leave the truck in 4 Wheel Drive with the engine off and jack up the front end. The wheel that spins by hand will be the broken hub or axle. The wheel that won't turn is working properly.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
