Results 1 to 4 of 4
    Sr. Apprentice freddie is a glorious beacon of light
    Apr 2008
    Lexington, SC
    Default leaking coolant/ trans?
    On my 2005 duramax I seem to have coolant leaking from some where above the trans or the trans itself where it is bolted into the back of the motor. I see it on both sides of the trans on the outer lower bolts. Does anyone have any idea as what it could be? And should it be covered under warranty? Oh and I have checked all the lines that I can see and no leaks.
    2003 Avalanche 4x4 110k mil.
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    It's not the transmission. Something is leaking from the back of the engine. Get a mirror and a flashlight and look behind the engine. Not sure about your warranty. Depends on the mileage.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Apr 2008
    Lexington, SC
    I was thinking that the diesel had a cooling system on the trans dunno for sure though.
    Feb 2009
    Reno, Nevada
    I'm pretty sure the trans is cooled through the radiator and an auxiliary cooler in front of the radiator. In any event you won't know till you look!
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
Similar Threads
  1. low coolant light comes on and the coolant level is good...
    By kukini808 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-14-2009, 08:31 AM
  2. 99 Chevy Coolant Leaking.... **SOLVED
    By Howie in forum Powertrain
    Last Post: 01-06-2009, 11:11 AM
  3. Engine Coolant leaking
    By Musclecargirl in forum Powertrain
    Last Post: 07-19-2008, 05:20 PM
  4. coolant leaking around oil pan/starter area....help....!
    By blk_clipse in forum General Chevy Tech Q&A
    Last Post: 05-22-2008, 04:53 PM
  5. leaking coolant....BAD
    By 95CTburb19 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 12-12-2007, 06:28 PM
