Results 1 to 5 of 5
    Newbie edean37 is a glorious beacon of light
    Oct 2009
    Ligonier, PA
    Default 00 chevy bad fuel pump
    hey all
    well it seems my in tank fuel pump has taken a crap at 170,000 miles...so its time for a new one
    I checked relay its working so now ...im gonna pull bed ...and check connectors for juice ...to make sure its a bad pump
    did some pricing and all the pumps are around $270
    My question is .......if i put and electric fuel pump lets say this one ... http://www.summitracing.com/parts/SUM-G3138/
    will that be able to pull threw the stock bad fuel pump
    i was told yes it will be able to pull threw the stock fuel pump
    and i was also told no that it wont have enough oommmfff to pull the fuel threw the stock in tank pump..there will be resistance
    anyone every try this
    seems 80 for a electric fuel pump is a far better deal then 270 lol
    but who knows
    any advice would help thanks
    Oct 2009
    Ligonier, PA
    anyone know about this ? because if i can hook up an electric fuel pump ...instead of replacing the intank pump ..i might be able to get the truck goin quicker
    Newbie Delco99 is a glorious beacon of light
    Mar 2009
    Default I'm not sure...
    I'm not sure if that will work or not. It might, but I'm just guessing you will have alot of acceleration and cranking issues. But I want to know what your truck did when the fuel pump went out becuase I think mine just took a **** at 167,000, but im not sure. My engine will turn over and try to start up, but will die out instantly. I was told it was the fuel pump but not sure if that is true. It only does it when it's hot but cranks fine when cold. Did your truck have simular problems when your pump went out?
    1999 Silverado Reg. Cab Short Bed 5.3L 325cid
    Legend dsfloyd has a brilliant future
    May 2009
    San Diego CA
    3 Post(s)
    Quote Originally Posted by Delco99 View Post
    That's what mine did when the fuel pump went out. As it got hot is when it would stop working
    David
    2004 Silverado 2500 Crew Cab 4x4, Airraid cold air intake, Throttle body spacer, Magnaflow exhaust (true dual to 2 in 1 out muffler), 6" ProComp lift (add a leaf and 5" superlift rear block), Bilstein shocks, 35's (Cooper Disoverer ST's) and 4.10 gears, Rhino Liner, fiberglass tonneau cover, extended stainless steel brake lines, firestone airbags.
    1960 Land Rover Series II 88
    2002 Nissan Altima (wife's Car)
    1999 Saturn SC1 (the new commuter car)
  5. #5
    Oct 2009
    Ligonier, PA
    well for awhile the truck would have idiling issues here and there
    it would act like an old caburated motor.....would have to hold the throttle down for about 30 seconds...then the truck would pick up and idle normal ...if not the truck would just stall
    then one day i was drivin and the truck shut off and thats it lol
    luckly i wasnt to far from my buddies garage ...towed it there let it sit overnight ...went the next day ...checked the relay and it was good ...i swapped it out for the horn relay ..
    tried to start it and nothing....beat on the tank a bit and it started for a few seconds ....then nothing ....
    the real trick is turn the ignition on and have someone listen at the tank and see if the pump makes a noise
    mine didnt make any noise .....so i replaced the pump with a Delphi pump from Napa.....and so far it runs fine
    truck is at 170.000 miles btw ...pump was an ac delco so i assume it was stock
    hope that helps
Similar Threads
  1. 1999 chevy silverado fuel pump not working
    By dugy40 in forum Performance & Fuel
    Last Post: 01-31-2012, 10:53 PM
  2. Fuel Pump Issues w/Chevy 3500 7.4L
    By rowekmr in forum Performance & Fuel
    Last Post: 07-20-2010, 11:43 PM
  3. 1996 chevy fuel pump
    By DESERTFOX19 in forum Performance & Fuel
    Last Post: 09-07-2009, 08:09 AM
  4. 1984 Chevy C20 Fuel Pump
    By 84ChevyC20 in forum Chevy C/K Truck Forum
    Last Post: 05-01-2009, 06:00 PM
  5. Twitching/vibrating fuel gauge - Not the fuel pump assembly.
    By Springthing in forum Audio / Video Electrical
    Last Post: 09-26-2008, 06:10 PM
