I have to replace my rear axle u joint. I think atleast. I get a squeak when idling at like 2-3mph and its not affected by the brakes and get a clunking noise when braking sometimes. anyone know some good how to sites for this. that would be great thanks
Here is a video: (Not a chevy, but pretty much the same procedure.)
[ame="http://www.youtube.com/watch?v=g76yO8p4TI0"]YouTube - Replacing a Rear Axle U Joint : Preparing & Installing a U Joint onto a Drive Shaft[/ame]
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
I dont know how loing GM continued this but on mine the factory ones are injected with plastic tohold them in place and it MUST be melted out with a torch, a heat gun wont get hot enough. I took my driveshaft to my mechanic and they melted it for me for no charge and the u-joint was like $25. Had I known about the plastic injection it would have been a 30 min job. My chilton manual said nothing about the plastic so check into that first for you truck.
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
as long as you have a torch its no problem, you will be surprised by how much actually comes out. then the new ones that go in have snap ring retainers and can be greased at anytime as they have zurks
Hypertech III
Reg Cab Long Box
Jason
Bookmarks
