Results 1 to 3 of 3
    Jr. Apprentice bucknasty is a glorious beacon of light
    Jan 2009
    Question 6.0l removal/broken exhaust bolts
    Huge problem.....! I went to put headers on my truck the other day when I got in there to take the old manifolds off I found that there is a broken bolt on both back sides of the motor and one in the front drivers side. I cant fit a 90 degree drill in there to drill them out or even see what I am doing. This is in a 2001 chevrolet silverado 1500HD with the 6.0L in it. If any one has any ideas on how to drill them out let me know. I have pretty much got everything undone to pull the motor except one bell housing bolt on the top drivers side.. How do I get that out??? if anyone can help me with this problem i would appreciate it..
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Thumbs up Tips for removing broken exhaust bolts or studs.
    Is there anything at all sticking above the surface of the cylinder head?
    If so you'll need the talents of a good welder. I broke a bellhousing bolt off and then I broke an extractor trying to remove it. I had the benefit of the engine being out of the car. There wasn't enough to grab with vise grips, so I took it to a welder who gingerly tacked a bolt onto the very small stub that was sticking above the surface. On the second try the bolt backed out with a gentle twist. Could be the heat from the arc welder helped "loosen" the bolt.
    Otherwise you'll have to consider lifting the engine high enough to get access for the usual tools.
    You could also consider some creative sheet metal modification. Seems to me there was a model of the Rolls/Bently that had holes in the fenderwell to allow access to the rear spark plugs.
    If the heads have to come off, you may just want to take it to a machine shop that has an EDM machine. They can burn the bolt/stud out without damage to the threads.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Jan 2009
    All bolts were broken off at least an 1/8th of an inch inside the heads.. Instead of taking my motor to a mechanic and paying $300 for him to drill out the bolts I pulled the motor.. the easy way I found it was to pull the intake manifold off in order to reach the bellhousing bolt that is on TDC of the motor. Drilled the bolts out replaced the water pump gasket new intake gasket put it all together with my new headers and she runs like a dream..
Similar Threads
  1. Broken exhaust bolt
    By egreg in forum General Chevy Tech Q&A
    Last Post: 10-09-2010, 12:02 PM
  2. Replies: 6
    Last Post: 05-27-2010, 01:30 AM
  3. Removal of Broken bolts?
    By ippielb in forum General Chevy Tech Q&A
    Last Post: 05-20-2010, 11:53 PM
  4. U-bolts
    By redneckarmyMP in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-29-2009, 05:46 PM
  5. how hard is it to fix broken exhaust stud? [Expired Topic]
    By viken in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-14-2005, 09:35 AM
