I've noticed about once every couple of months that my rear end feels like it slips on acceleration from a dead stop. The surface is dry, gravel/rock free. The traction light does not come on either. Not a serious problem, but enough for me to ask.
If you've had this experience please let me know, thanks.
Are you sure it's the rear end and not the tranny? It might be that eaton setting in place but i don't know why it would do that on just gravel
I only ruled out tranny cause dealership said tranny is good. They haven't heard many complaints on this matter. My brother in law said he's noticed this twice in two months with his new Silverado. Just fishing for more ideas. Thanks
Can you better describe what it is doing? Rear ends are all gears, so they rarely slip, unless there are teeth missing from the gears (and then I wouldn't expect it to be only once every couple of months). And then they often make noise to go with the broken teeth. This scenario should be obvious if you remove the diff cover and visually inspect it.
Automatic transmissions are more suspect with slipping, because they use hydraulics, clutches, and bands, which are prone to "slipping". Did the truck act up for the dealership when you had it in? It's really hard for a technician to declare something bad if it doesn't act up for him consistently (which a "once every 2 months" kind of problem might do).
Could it possibly be an engine hesitation kind of thing?
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
might be your torque converter. I have been told that they are having problems with them on the nbs.
08 silverado
4.8
K&N cai
single in dual out cherry bomb pro
leveling kit
custom painted bow ties
Bed liner
Tinted windows
20inch Cruser Alloy Switchblades
Goodyear Eagle GT2 285/50/20
1 truly heavy foot + Wait4meperformance SCT Handheld
100 shot of Nitrous Dyno tune system
SS front bumper
Matching painted front grill and bow ties
Do you actually feel a "slip" or does the "rear end break lose" on take off and spin? I just wanted to be clear is all.
My '09 will spin with little accelation at times, usually only when the road is damp..then the eaton kicks in and it grabs. I was just wondering if that "may" be what you are feeling?
I know most of the tires that come many of them dont have very good traction, unless you get the mud and snows as standard equipment. I have the all seasons on mine and I know they wont be worth a darn when winter hits.
Actually, when accelerating from a dead stop, the rpms increase, and then, like letting out a clutch in kinda lunges foward. Doesnt happen very often.
Ive been given a couple ideas from gm mechanics that, 1) this is normal, due to vehicle placement at take off, ie. if wheels are turned, on a up grade or down grade, that the different forces affect the torque converters reaction. 2) Transmission fluid filters clogged or malfunctioning, but usually will see more frequent problems. 3)possibly need transmission inspected??
I guess I can live with it, I was hoping someone would say,oh yeah, i've heard of this its.....
I do appreciate any other input.![]()
How long ago did you get your tranny checked? Take out the dipstick for your tranny and smell it, if it smells burnt then you might have some problems, otherwise, it may be your torque converter
i will try that, thanks.
I think mine might be doing the same thing. Sometimes when i start to go from a stop the rear end "clicks" . Like it slightly jumps or something. Also if i hit the brake and then hit the gas, it will do it. I'm woundering if this is normal.
Greystone Matalic, LS
Audio Mods: Kicker S8L7, Kenwood Amp, Pionner rear speakers
Electronics: Viper 5701 Security/Remote Start
Interior: 10% tent,
Exterior: Bug Shield, OEM bed rails protectors, toolbox, tonneau cover, debadged.
Engine Mods: Airaid Intake
Suspension Mods: Superlift 2.5 in. lift struts, Procomp 2" add-a-leaf in the rear.
Bookmarks
