So for those of you with the 6.0 who have an intake AND exhaust, what kind of calculated (not theoretical) gas mileage are you getting? Is it possible to get 17-18 mpg out of these trucks somehow?![]()
The old man can easily pull that on his 07 NNBS crew Z71 6.0, usually closer to 21, but for an HD might be harder, I would assume they have a 4.10 in the back for the towing.
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
If you are getting 12-14 mpg, you are doing about the best you can....
I get just about that and here is what I have done to mine...
Changed to 265x70x17 tires and wheels to reduce the 4.10 ration to about 3.90....lost performance and mpg....down to 10-11 mpg
Added K&N Filter system....no change for $235
Added Magnaflow catback with dual tail pipes....sounds great....no change in mpg...$425
Had a Blackbear tune for $350....got some performance back and mpg back to 13-14...
So, $1000+++ later, the truck sound great, runs good and still gets the same 12-14 mpg...
You have a 6000 pound truck with towing gears....12-14 is about all it will give....
The only HD that gets worse mpg is my son's 8.1 L 4x4....allmost gets 12 mpg on the hiway, and 8-9 around town...pulls like a diesel though....
You have a 2500 HD and expect to get gas mileageI am lucky if I get 10. I knew what I was in store for when I did all the mods to mine. Its the nature of the beast.
"You underestimate my willingness to resort to violence to resolve this conflict"
2006 Chevy Silverado 2500 HD LT
(8" Fabtech Suspension Lift, 3" Performance Accessories Body Lift, 37x13.50 Toyo MT's, 20" KMC Rockstar, K&N FIPK, Edelbrock Headers, Edelbrock Extreme Travel Shocks with Reservoir, MagnaFlow Dual Exhaust, Black Bear Performance Tune)
Yeah Im cool with the gas mileage. Im just coming off of a 400hp turbo 4 banger that got 35mpg and dusted the piss out of any v8 on the road. Theres the obvious pump shock I think that everyone with the 2500HD went through. Im glad you guys posted your comments, it gives me some real good insight. Thanks for the help boys.![]()
Most likely you wont get that 17mpg plataeu but what helps is watchingyour RPMs, when accelerating try and keep the tach under 2000RPM and that will help a bit might get a gallon. As for the exhaust and intake, thats up to you everyone gets different results
Hypertech III
Reg Cab Long Box
Jason
15.6 mpg with my 2009. 3.73 gearing. When towing my 32' 5th wheel mpg goes down to 8-10. I'm able to maintain speed at around 55-60 on most hills with no more than a 5% grade. At 5% and greater speed drop to around 45mph...rpm around 3500 - 4000. So far so good. The 6.0L vortex is a great engine.
"Nothing beats a fail but a try".
Wow so even with the better gearing the gas mileage isnt that much better. I seriously love this truck. I dont know if Ill take my car out of winter storage or not in the spring!![]()
My neighbor just last month bought a 2009 GMC regular cab short bed with the 4.8 engine and that system that goes from 4 cylinders to 8 cylinders (forgot the name)...
Even with that light of a truck he get 19 mpg on the hiway....he is mad because the salesman said he would get over 22....he believed the salesman....oops.
Point is that a truck with not get gret mileage, no matter how it is set up...of course, I would love to get 19 mpg out of my 6.0l, but that will never happen.
2007 Silverado Classic
HD 2500
4x2
Locker
4 speed automatic
6.0L gas
Hummer H2 17" wheels
K&N CAI
Magnaflow Cat back
Blackbear Performance Tune
Bookmarks
