Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Jr. Apprentice BamBam is a glorious beacon of light
    Nov 2009
    Default stalling 5.7 tbi
    Ok, guys...I joined this forum just for this problem. Recently bought a used 92 Sub with 5.7 TBI. It's my first GMC ever . It ran ok, but was in need of a tune-up. It would stall while sitting at idle in park or when in gear at a stop sign. It fires right back up very easily. I replaced the plugs, wires, cap, rotor, and air filter. Ran better, but still stalled. Did some research and replaced the Idle Air Control Valve...still stalls. Replaced the TPS next...same prob. Runs great as long as you're on the gas. I can take it down the highway with no problem at all. But if I sit and let it idle for more than about 10 seconds it dies. So I end up double-footing it to keep the rpm's at about 800 so it doesn't stall. Any insight? Thanks in advance!
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Intake manifold gasket leaks are common. Test for a vacuum leak.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Nov 2009
    The adventure continues! In all, I have replaced the TPS, IAC, MAP sensor, EGR valve, all vacuum lines, fuel filter, plugs, wires, cap, rotor. I took the injectors off and cleaned the assembly, however you can't really clean the injectors, can you? I have yet to test for vacuum leak, but it did run better after I replaced the vacuum lines. Just thought maybe someone had some more insight now that I have replaced more parts.
    Jr. Engineer Chris Miller is a glorious beacon of light
    Mar 2009
    It's your intake manifold gasket. My mother had the exact same problem in her '94 suburban. The passenger side gasket was leaking at the #2 intake port.
  5. #5
    Sr. Apprentice justcuz is a glorious beacon of light
    Aug 2007
    Alta Loma, Ca.
    Does it lope or just stall. Put it in park and rev it up, look and see if the EGR valve is opening. This is the problem I am having. The EGR valve is opening with the vehicle in Park or neutral and is almost stalling when you stop and idles very lopey.
    I have swapped out the EGR Valve, the EGR solenoid, the MAP sensor, the Temp sensor and adjusted the neutral safety switch. I swapped these out with known good parts from my 93 Suburban. Nothing worked.
    It throws a code 32 (EGR) and when I plug the vacuum line or unplug the EGR solenoid it runs fine, minus the EGR function of course.
    I looked at a wiring diagram and see that the EGR solenoid shares a curcuit with the O2 sensor. I wonder if the O2 sensor is bad?
  6. #6
    Nov 2009
    Ok, in addition to all the work done previously, I have replaced the intake manifold gasket...same problem still. The only other things I can think of are fuel pump (which I was told by previous owner was replaced), and possibly the coil???
  7. #7
    Jr. Engineer Project Reaper is a glorious beacon of light
    Mar 2009
    Socal
    i dont know if you can get this tested but if your running rich as hell because of a bad O2 sensor it will lope and stall at idle. it might even throw, i would check those. if it was just a bad fuel pump then you could just check the fuel PSI lvl and that would tell you right there.
    1997 K1500 Silverado 4X4. Black Exterior, grey/black interior. 35X12.50X15 wheels and rubber, ProComp 6inch lift 6 shocks in the front 2 in the rear, 3 inch body lift, a few cosmetic mods. Nothing major. Custom leather interior, and stereo upgrade is the future mods.
  8. #8
    Nov 2009
    Well I found another vacuum solenoid for the egr valve that I overlooked while replacing stuff so I'll replace that as well as the O2 sensor and the coolant temp sensor. That will be all of the solenoids and sensors on that engine. Other than that I have no idea and will probably take it to a GM Garage and let them diagnose it.
  9. #9
    Jr. Mechanic k.daddy1 is a glorious beacon of light
    Jul 2008
    Bluegrass Country
    Quote Originally Posted by BamBam View Post
    Replace your fuel pressure regulator. Your not keeping a constant pressure to the fuel system.
  10. #10
    Nov 2009
    Unhappy
    Ok, I replaced the EGR Vacuum Solenoid and coolant temp sensor. No change. Everyone seems to have a different idea as to what it might be. In all I have changed:
    1.) plugs
    2.) wires
    3.) cap & rotor
    4.) fuel filter
    5.) EGR valve
    6.) EGR solenoid
    7.) Idle Air Controller
    8.) Throttle Position Sensor
    9.) Map Sensor
    10.) All vacuum lines
    11.) Coolant Temp Sensor
    12.) Intake Manifold Gasket
    It throws no diagnostic codes other than 12, runs great down the highway, never fails to start on the coldest of days. When it's stone cold, it will idle fine for about 15 minutes till it warms up and then stalls. I'm at my wit's end and it's quickly turning into a money pit.
Similar Threads
  1. 95 one ton stalling???
    By tbioneton in forum Powertrain
    Last Post: 08-17-2009, 12:01 PM
  2. wtf? TBI stalling?
    By L0sts0ul in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-30-2009, 12:38 AM
  3. stalling
    By mojomaki in forum General Chevy Tech Q&A
    Last Post: 05-22-2009, 09:44 PM
  4. Why are you stalling?
    By b8k2jha in forum General Chevy Tech Q&A
    Last Post: 02-15-2009, 06:09 PM
  5. Stalling
    By TB6493 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 12-01-2005, 01:11 PM
