Results 1 to 2 of 2
    Newbie Robzilla! is a glorious beacon of light
    Nov 2009
    Default Need advice: 99 Silverado radio shorting and p0430 issues
    I have a 99 SIlverado 1500 with 170k miles. The engine was rebuilt about 8k miles ago and it runs strong.
    Recently, I started noticing a few issues. One is the stereo shorts out at sometimes when I hit a bump, shut the door, click the seatbelt, or when i shift (its automatic). There is an aftermarket stereo and subwoofer installed, as well as speakers (alpine stereo with jbl sub and infinity speakers). In all honesty I'm not that savvy when it comes to vehicles and I'm curious to see what others think the cause of the radio shorting out is?
    Secondly is that the "Service Engine Soon" light came on. Now the truck was up for an oil change which was completed, also, that same day I put gas in. The owners manual noted that cheap gas could cause the light to come on, I used Chevron? Luckily I had a Hypertech programmer handy and noted the code that came up (p0430). This resulted in google searches revealing a "Catalyst System Efficiency Below Threshold (Bank 2)." Is this true? Also, is this referring to my Catalytic Converter or a possible faulty O2 sensor? Any feedback from someone with similar experiences will be greatly appreciated. The truck does have stock exhaust and since I live in CA with super strict emissions laws, I am considering going with an aftermarket exhaust instead of just buying a new cat system. Any comments on that would be appreciated too.
    Thanks for any help, it will definitely be appreciated.
    1999 Chevy Silverado 1500
    CST Lift on 35's
    First truck, straight out loving it
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Aftermarket stereo points to a fault in the installation. Pull the head unit out and check the wiring. Was an adapter plug used or was it just spliced into the harness. Either way a loose connection, or bad ground could cause your symptoms.
    With the year and mileage of your vehicle I'd guess cat, but a O2 sensor is cheap enough to try that first.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
Similar Threads
  1. Radio issues
    By 03blueburban in forum Audio / Video Electrical
    Last Post: 07-12-2010, 12:11 PM
  2. 4L60E 1-2 shift issues...any advice appreciated
    By rotaryenginepete in forum Powertrain
    Last Post: 06-14-2010, 08:14 AM
  3. Brake Noise Issues - Need Advice
    By mkruluts in forum Lifted & Offroad Suspension
    Last Post: 07-22-2009, 11:56 PM
  4. OnStar/Radio Issues
    By JollyGreenGiant in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-21-2009, 08:58 PM
  5. Interior lights shorting out...
    By 95suburban4x4 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-24-2007, 04:45 AM
