Results 1 to 2 of 2
    Default 97 K1500 engine light reset
    My burb with 266K miles has the check engine light comming on with code 0753. This is apparently the second gear solenoid in the tranny. Dealer replaced the solenoid but code wouldn't clear he says due to feedback circuitry going to the ECM (PCM). It shifts fine but I don't (can't) want to spend the money to replace the ECM but need to get the truck inspected. What can I do to temperarily turn off the check engine light while I get it inspected and is there a way to repair these ECM (bad solder joints maybe) or find a cheap replacement ?
    One other question, are the O2 sensors the same in all positions on the exhaust system ? I believe I may have a slow O2 sensor and would like to just switch the position to see if there is a change. These are the original senors on the truck.
    hopefully Jimmie can answer your tranny question but for your O2 sensor you can swap them around to see if the code follows the sensor or not
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
  1. '95 K1500 Transmission/Check Engine Light
    By rdnkdrummer in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 02-12-2011, 09:42 PM
  2. 97' K1500 Check Engine Light Reset
    By dsquared in forum General Chevy & GM Tech Questions
    Last: 11-12-2009, 01:49 PM
  3. service engine light reset
    By 9191gmc in forum Chevy Silverado Forum (GMC Sierra)
    Last: 08-18-2009, 07:10 AM
  4. oil light reset
    By mashburn in forum General Chevy & GM Tech Questions
    Last: 07-14-2009, 01:27 AM
  5. ABS Light Reset
    By jtwh20 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-30-2008, 09:05 PM
