Results 1 to 7 of 7
    Jr. Mechanic nlocho11 is a glorious beacon of light
    Apr 2009
    CT
    Default MPG Drop after upgrades
    ok so i just put in ac delco plugs and msd wires, a spectre cold air intake, oil change, brand new tires, all thinking it would improve the truck's performance. however, as the comp. is showing me, my mpg has declined from 17 to 15 average, and i'm noticing my instant econo is lower in the same places i would previously drive compared to now. is this something that will work itself out overtime and i'll see the benefits, i realize 2mpg isnt a huge loss, but i was expecting the results to go the other way. any thoughts?
    Legend ejohnson03 is a glorious beacon of light
    Aug 2009
    Woodhaven, MI
    Not sure why new Plugs and Wires would be an issue, but tires will very.
    Even if they are the same size. the tread pattern and material can cause a little change.
    Pavement sucks...
    1994 K1500 4x4 Ext. Cab
    PCM chip and Xenon 8000k bulbs
    350cu.in bored over .050"
    balanced Crank, 10:1 compression
    Flat top pistons,cam,ported heads
    Option Racing Cold Air Intake
    Holley Throttle Body Spacer
    Accell Igition, 45kv coil
    FloTech Headers, no CATs, dual exhuast
    Goodyear Silent Armor A/T 305/70-16
    Pioneer SupertunerIII CD USB Bluetooth
    Kicker ZX200.2 ZX Amp
    Kicker Audio COMP 10" Subwoofer
    Newbie andymax is a glorious beacon of light
    Nov 2009
    If it's not too much of a job, switch the cold air intake back to stock...there is a lot of data out there about them ruining mileage on some cars and improving on others. this may be a function of the computer not playing nice with higher volume of air...
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    if the tire you put on are more aggressive or are heavier it will cause a drop in mileage
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
  5. #5
    Apr 2009
    CT
    the tires could be it...i kept the stock 245/75/16 but went with 10ply instead of passenger tires like were on it before...could be it?
  6. #6
    Sr. Apprentice raueda1 is a glorious beacon of light
    Dec 2008
    NY
    Are you saying that the new tires are LT's? If so they almost certainly need sustantially more pressure that the OE passenger tires. Iif you're running them at the same pressure that could acount for loss of mileage, you''re underinflated.
    2001 Surb K2500
    6.0L, 4L80e, 3.73 rear
    Diablo Predator tuned
  7. #7
    Apr 2009
    CT
    Quote Originally Posted by raueda1 View Post
    yeah, the new tires (mastercraft a/t's) are running 80psi, though Town Fair Tire didnt properly inflate them as i checked the other day. put the right air pressure in and are running better now.
Similar Threads
  1. 4.3L upgrades
    By nthammack in forum Performance & Fuel
    Last Post: 03-28-2011, 04:40 PM
  2. upgrades?
    By npverhey1 in forum Performance & Fuel
    Last Post: 12-06-2008, 07:28 PM
  3. upgrades
    By Steve in forum Announcements
    Last Post: 10-24-2007, 07:56 AM
  4. Upgrades? [Expired Topic]
    By Newman in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-06-2007, 08:44 PM
  5. Upgrades? [Expired Topic]
    Last Post: 12-24-2006, 06:43 PM
